Question about Measuring Tools & Sensors
What would cause a briggs to only run at idle or fast
    New Friend:
  • 171 Answers
Governor inside engine has exploded.
Posted on Jun 23, 2013
How to adj carb on 2cylinder briggs?
Sounds like the carb needs cleaning, it's running too rich. First check the choke cable is not broken and travels full range.
Jul 27, 2014 | Garden
Motor runs at too high a speed. Throttle cable has no effect except to shut the motor off.
running fast would be a governer problem. wont idle sounds like a fuel problem. try cleaning carb. no power sounds like valve problems. if you feel profiecient make sure valves are sealing properly and ck. clearances.
Jun 10, 2013 | Heavy Machinery
Toro briggs OHV runs too fast
throttle spring could be broken stretched or missing
Nov 14, 2012 | Toro Lawn Mower With Toro Power Tools
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
My mower idles super fast starts after its primed then dies. i have taken apart the carb. and cleaned it all. what now
You need acarb kit the gaskets need to be replaced after a while they will wear out and need to be replaced if it has a plastic bowl get the new replacement it will solve your problems and sometimes if you get moisture in the gas it will cause it to run funny
Jul 18, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Describe your Briggs & Stratton
you need to rebuild carb and check groverner spring
Jul 16, 2009 | Briggs & Stratton 66set Panzer Tractor...
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
