Question about Oster Fpstdh0101 4tray Electric Food Dehydrator
Motor g63b manual - Oster Fpstdh0101 4tray Electric Food Dehydrator
5 years ago I bought a Prowler 12 Volt Trolling Motor, but due to poor health it wasn't installed. I'm in search of an operators manual so I can install/operate this Trolling Motor.
Here you are. You can download your manual from the Internet.
I use GOOGLE and typed this in ***** (Prowler 12 Volt Trolling Motor, manual.) **** Simple and fast. You can copy and paste this to the browser Prowler 12 Volt Trolling Motor, manual
Oct 20, 2017 | Boating
Hi, i have a 1983 dodge ram 50, i think my fuel filter is pluggin up, so my question is, where is the filter located at and is there more than on? the engine # is G63B Mitsabishi Model L026....Thank Y
I'm not 100% sure on the exact model of your vehicle, but if you check on the inside of the frame on the side your fuel tank is on it should be there.
Oct 05, 2014 | 1983 Dodge Ram 50 4WD
Where is the water pump on a 94 Mitsibishi Mighty Max
great question , WHERE.?
The answer is usually on the front of the engine, so the fan belt can spin it.
its a pickup , RWD PU.
no engine options stated.
here is the list. each are different.
2.0 L G63B I4
2.4 L 4G64 I4
2.6 L 4G54 I4
2.5 L 4D56 diesel I4
2.5 L 4D56 TD I4
3.0 L 6G72 V6 (4WD) on most engines see the fan belts.
and one goes to each accessories
the on going NOT TO THE P/S and A/C and Alternator
IS THE PUMP PULLEY.
using the process of elimination logic. (no engine stated)
don't feel bad 99% here never say. par for course.
Sig: I must ask questions first, I'm blind, and my tools can't reach, dig?
Jun 21, 2014 | Cars & Trucks
Where can i get a carboratur for a dodge ram 50 model # l026 engine # g63b
Holley makes carby's for most engines so check with a speed shop/auto spares shop and check out the catalogue for one suitable for your engine.
Dec 08, 2013 | Dodge Ram 50 Cars & Trucks
Good morning, thank you for the help with the comments. My truck was runnin fine till this mornin. I was drivinin up a grade and got a power loss, i had a small load of wood on but have pull this grade...
sounds like you are losing pressure could be the exhaust or the piston rings or the head manifold leaking. if you have the engine pressure tested should tell you witch is the problem rings is mostly the problem on a work hourse engine. .
Oct 15, 2013 | Dodge Ram 50 Cars & Trucks
How do I set the Balance Belt & Cam Timing Belt on a Mitshubishi 4g63 16v 2.0l sohc engine please?
tdc @ 1cyl. cam shaft has triangle stamp mark on face of the gear.both valves for # 1 should be closed in compression stroke and triangle should be pointing at left side top of head(9 o'clock) on the silent shaft and oil pump pulleys both marks must align with each other , use a metal rule for a straight edge.it would be wise to purchase a haynes manuel for your vehicle.this manuel gives you illustrations and step procedures to align all components on your g63b engine ....chris
May 09, 2009 | Mitsubishi Colt Cars & Trucks
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Oster  Fpstdh0101 4tray Electric Food Dehydrator Logo
115 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
