Question about Sony Televison & Video
Sony rangs tv
Not working can not change changes
    Top Expert:
  • Sony Master
  • 74,136 Answers
083.072.099.000.028 are the codes to check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box; can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Posted on May 09, 2013
Blinks red 3x why ?
you have a lamp or lamp door switch that is failing. The only way to fix it is to replace the switch that is bad. The price range to have this repaired normally runs between $200-300. The range is so wide because if the lamp door switch is bad then it is a lot easier to change, if the lamp switch is bad (which it normally is) it is mounted on the light engine and almost the entire tv has to be disassembled to change it.
Mar 11, 2015 | Sony Grand WEGA KDF-60XS955 60" Rear...
Need code for Sony DVD and Sony tv and how to program it I have ge 24991 1312 universal remote
Buy a SONY universal remote.
Most universal remotes do not support SONY, but a hand full do.
Packaging should explicitly state support for SONY.
Most IR remotes can use a carrier frequency range of 30-56KHz, with most using normally 38-40KHz, or likely the GE universal. SONY is in the mid 50KHz range, other manufactures in upper 40KHz range and audio equipment Bang & Olufsen and, Kenwood use a 455KHz frequency. The carrier is what your TV or DVD is tuned to see and the codes are transmitted like Morse code for digit ones and zeros to say, change channel or play.
Short to say if you don't find an auto code scan that works then try another manufacture. Manual can be found online at manualslib if lost.
Feb 27, 2015 | Sony Televison & Video
I need a user manual for a Sony Bravia tv
Sony's website will have the information about your TV.
Sep 07, 2014 | Televison & Video
My dell 32in LCD tv is showing an out of range error
sounds like your apple TV is putting out a higher resolution than your TV supports. Is the resolution on your tv 720 rather than the 1080 that the apple tv outputs. If that's the case go into the menu on the apple tv and change the output on the apple tv to 720.
Feb 02, 2014 | Dell W3201C 32 in. LCD Television
How to fix out of range problem on sony bravia with pc
Well I just changed the resolution settings in my android box to 720 from 1080p > plugged it in and my box now works...simples.
Jan 29, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
When Tv is turned on picture comes on for a few seconds then goes out, sound works even when there is no picture.
I have a similar problem, while searching internet, came across a solution maybe. Its the inverter board. the inverter board controls the picture in the flat screen televisions. Board may contain a power source capcitors, similar to the ones on the power board. I had changed the capacitors on the power board two years ago, capcitors from Radio Shack $ 1.67 each, vs. techincian $ 550.00.
You may want to also check YouTube, which shows you how to change a inverter board, cost of board ranges $ 55.00 to $ 105.00 on ebay. You can also just change the inverter on the board, may take some work on your end. Some samsung tv have two (2) inverter boards.
Good Luck
Sony 1080p LCD 120hz at Sony Store $ 490.00, 24 mths no interest. Christmas special
Dec 03, 2010 | Samsung LN-S4051D 40 in. LCD Television
Sony KP-61XBR48 Service Menu Item Keeps Changing
the only thing to do is pick which video mode you want (tv, vid1,2,3,etc) and then turn off and then immediately on for an hour or two and then the picture will come on. I,ve heard it's an internal transformer problem.
Sep 26, 2007 | Sony KP-61XBR48 61" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
