Goodmans tv flicking on and of
My tv keeps flicking on and off. I am not sure why but any obvious things such as remote batteries or something like that I have already addressed. Please help.
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Open the back cover then tried to dis connect the supply going to the inverter board for the screen back light whci may cause of shut off. let see if the indicator will stay to green and not turn to red.
Posted on May 09, 2013
  • brad smith May 09, 2013
    Hello I have taken the back off but do my know what the inverter board looks like etc. can you help
    Ok I have found the problem to be what I believe is the inverter. Is there anything I can do about it?
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Posted on Mar 25, 2006
techman
  • 3130 Answers
SOURCE: tv flicks
Most likly a tuner problem my friend.
Posted on Mar 26, 2006
  • 518 Answers
SOURCE: Zenith tv model #A32B41W
You probably need to get into the Menu > Tuner Setup and set it for "Cable" instead of "Off Air".
Hope that helps...
Geno
Posted on Mar 22, 2008
Hi my mother's Goodmans LD2614 tv has lost all pre-set channels, and she has lost the book that came with it. Phil
Unfortunately, this TV model was made by Comet under a license from Goodmans. Comet held all the technical information related to the model. Comet's business failed. If it was a warranty matter, you might get something. But you are not going to get technical support. That said, the 050 code entered into a remote being used to setup the TV may be of help.
http://www.tvtuning.co.uk/makes/goodmans.htm
http://www.wowforbusiness.com/docs/wow/product-support/digital-adapter.pdf
Maybe the above pages will be of help.
Aug 09, 2017 | Goodmans Televison & Video
Goodmans tv is stuck in radio mode, the radio/tv button doesn't change it. How do I get back to tv?
It is most likely that button is damaged. You can change that button and see if it works.
Nov 15, 2016 | Goodmans Televison & Video
When charger is plugged into the laptop ( Samsung R530) , the screen flickers a lot and when on battery mode flickers a bit
um well its obvious somethings not right it could range from a numberous amout of problems it looks like your power port may be faulty but its almost out of the answer it could be something wrong with your power supply affecting the gpu.This problem isnt something you or i could fix buy doing something within the computer by tweeking something.The best thing to do is to take it to your nearest repair shop.I havent heard of a laptop doing this, its a first time thing.
Mar 20, 2013 | Computers & Internet
Humax FOXSAT-HDR remote control is not working batteries are okay
I'm not familiar with that particular remote control, although in my experience the most common fault in remote controls generally, apart from batteries/connections/leakage, has been caused by problems with the ceramic resonator:
http://parts.digikey.com/uk/1/73869-ceramic-resonator-455-khz-ztb455e.html
Almost all remotes use these and there are 3 common problems:
1). The legs are fragile and can break off if the remote is dropped
2). The legs are plated with something that doesn't 'take' solder very well so the connections need resoldering.
If one of these 2 problems has occurred I usually attach the new or repaired resonator to the PCB with double sided tape or glue, so that the solder joints aren't the only thing holding it down!
3). The resonator can be broken internally - usually after dropping the remote. Sometimes you can hear this if you flick the resonator GENTLY in a quiet place. Only flick gently or you'll break it.
They're readily available and quite cheap.
Dec 01, 2011 | Televison & Video
Goodmans 42" LD4 255 HD.\r\nlost remote and using
Yes,ur tv does require a tv orginal remote will help u to used,but the child lock mode must have a secret codes to enter it.Can't turn tv on,must have the tv original remote to enter child lock secret codes though.Tries Goodmans website look for there 1-800.. call ask their customer service they can help to erase the child lock secrect password,if u don't know it.Try website Remotes.com to buy the tv original remote.
Jul 18, 2011 | Televison & Video
My second television I have freesat ,the remote a goodmans will not work,it is not the batteries,have only had the goodmans free sat for a couple of weeks is there anything I can do?
First find out how many digits of code your remote neeeds for your TV? Then you can input the code on number at a time until it works. Some remote only use two digits, but the lat model TV may need five digits. You can google the codes for goodman's remote for freesat if you know the TV brand name..
Dec 03, 2010 | Televison & Video
CANT FIND THE CODE TO TUNE IN MY SKY REMOTE,MY TV IS A GOODMANS LD3266D
On your sky remote press interactive-skyactive-help-set up my remote follow instructions. If your Model No not on list keep checking for updated info. If no joy then contact goodmans customer services.
Sep 16, 2009 | Goodmans Televison & Video
The remote control for my goodmans LD1940WD does
just go and buy a universl remote and program it and it should do everything you want it to do.
Jul 28, 2009 | Televison & Video
Goodmans w282ns silver
in your remote control there will be one button calles ASM or auto search mode you press it (or auto) tv will tune one by one channel automatically & it will stop. now from prog. button you can up &down channals. from vol +&- vol up& down. good luck.
Sep 19, 2007 | Goodmans 289NS 14" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
