SOURCE: AC STOPPED WORKING....FAN WORKS BUT
Hi!
Those 2 problems are certainly not related to each other. The only common thing is that both problems require proffesional to solve. Most probably the AC needs a freon refill.
Hope it helped,
Bogdan
SOURCE: static on am radio (comes and goes). fm is fine.
A static on AM is just interference. Similar to operating a mixer when you are watching TV. You would remember the grains in the TV but no audio disturbance because, video is AM transmitted and audio FM transmitted. A static on AM radio could be due to many factors in the car. The ac system, the music system itself or the engine rpm. The solution does not lie in finding out which is creating the noise, it lies in insulation. Check the antenna and change it if needed. That should fix it.
SOURCE: I noticed static on fm station on my radio. the
i would get the alternator checked, sounds like its leaking ac current which can also kill the battery
