Tech solutions/model PS-067/B
Gear availability?
Do you sell the safety interlock switch for the TS4500, model no. PS-067/B?
http://shredderparts.com/tech-solutions-1.php
If you could take it apart, you could bypass the interlock. I would not do this if you have children, unless you buy a lockout box.
I would try and glue the pin with superglue.
Aug 16, 2015 | Tech Solution TS-4500 Shredder
Power supply damaged, Can I replace it with any other model power supply?
A standard ATX PS won't fit in your low profile case. The plug types can be different too. Usually there's a schematic with a PS that describes the wire color of each voltage. So you could conceivably shove the pins out of one PS plugs and insert them into the different plug, or solder the wires to the correct pins, and leave the PS outside of the case.
Nov 16, 2013 | HP Compaq dc7600 Small Form Factor PC...
Will not feed paper in
Most likely a gear has either stripped or broken inside the shredder. That model has been discontinued for quite sometime and no parts are available for it.
Jan 22, 2011 | Tech Solution TS-4500 Shredder
I have a stripped gear in my TS-6000. How do I order replacement parts?
The Tech Solutions shredders have been discontinued for years now. No parts are available. I called the 800 number and was told all parts were liqudated due to discontinuance of the shredders.
Jan 12, 2011 | Tech Solution TS-6000 Shredder
I need to know if model #20024 starter unit will work in my 2007 chevy aveo
This unit will work with your vehicle but if your vehicle is equipped with a transponder type security system you will need to add an immobilizer bypass.
Some bypasses that are available can be found at the following links:
http://www.xpresskit.com/VehicleCompatibility.aspx?p=-1&year=2007&make=Chevrolet&model=Aveo&ps=1&s=0
http://www.idatalink.com/search/index/model/4770
Nov 03, 2010 | AutoCommand Remote Start and Security with...
TS-6000 Shredder Problem
1800 639 3803 tech solutions service hot line for the ts6000
Aug 18, 2008 | Tech Solution TS-6000 Shredder
Ts 4500
Actually you more than likely have a broken or stripped gear. Contact manufacturer for parts availability.
Feb 06, 2008 | Tech Solution TS-4500 Shredder
A4 TECH RFK-25 KEYBOARD
Please try below steps:
1. The most common problem when faced with a non-working keyboard is an improper connection. Try reconnecting your keyboard, restart your computer and see if that fixes it.
2. Turn off the system. Unplug the keyboard connect and inspect for any bent or broken pins. If the pins are bent, then it is possible to gently straighten them using the tip of a ball point pen or mechanical pencil. If the pins are broken, then replacement of the keyboard may be necessary.
3. Try updating the device driver. Visit the manufactures web site for the latest driver available for your keyboard make and model. While at the manufactures web site. See if there are software patches or updates available for your keyboard. If there are, go ahead and install them as well as the updated driver.
4. If you are using a multi-media type keyboard, be sure to delete the software before installing any new drivers for this type of keyboard. Install the updated driver for the manufactures web site, then re-install the keyboard software. If any software updates or patches are available for your multi-media keyboard, install them at this time. Delete the keyboard software by using Add/Remove Programs (Start>> Control Panel>> Add/Remove Programs). If you receive a prompt asking if you would like to remove all shared files, answer "No to all". Then click OK.
Further steps on this issue:
Disconnect the keyboard from the computer and connect another known working keyboard to it. If this is a PS/2 keyboard and connecting multiple keyboards or a known working keyboard to the computer PS/2 port does not work unfortunately it's likely that the PS/2 port is bad. Because this port is part of the motherboard this will require that you replace the motherboard.
Alternatively if replacing the motherboard is too costly or not an effective solution you could also consider using a USB keyboard if USB ports are available on the computer.
I hope this should resolve the issue.
You can mail me at thumuvikram@rediffmail.com for any further assistance.
Bye.
Oct 17, 2007 | Compaq Keyboard
53 people viewed this question
k24674
