Question about HP Pavilion ze4935wm PC Notebook
Screen stays black when I turn it on
The screen on my HP Pavilion ze4935wm stay black after I turn it on. The indicator lights come on but the screen is blact except for a very faint HP logo.
    Master:
  • HP Master
  • 630 Answers
My point of view RAM section direct connect to display so first you check RAM.Then check processor Fan proper working or not. and finally power connection in screen.
Thanks..
Posted on May 08, 2013
  • 359 Answers
SOURCE: Why did my HP Pavilion ze2000 screen go black?
john79:
I know that you had a chat about this matter, and I hope that your issue was solved. However, I had made a note of it when I saw the chat go through. I was unable to help at that time, but remembered having seen something of this nature and wanted to follow through on it.
Although the ze2000 is not listed, other 2000 models are listed in the following link as defective - and recognized as such by HP - with this very specific defect. (Please see http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&product=18703&docname=c01087194.)
Again, if your issue has already been solved, congratulations. Otherwise, I hope that the information provided here will be of use to you, either in fixing the equipment problem yourself (perhaps with a BIOS update) or by convincing HP to do something about it. At least you would be armed with good solid documentation of their recognized issue!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 26, 2008
SYSTEM ONE
  • 85 Answers
SOURCE: Hp Pavilion dv1000 Black screen
It is either the inverter board or the bulb
If it looks pink in color than it is the bulb and that can be quite the intensive project to replace
If it is the inverter board than that is not so bad and you can pick up an inverter board on eBay usually for around $10 to $20 and that usually installs right under the LCD screen (usually screwed to the LCD screen)
The inverter board is what powers the light bulb the data cable is totally separate function.
If you can see data on the screen with a flashlight but there is absolutely no light coming from the screen at all ever than it is probably just the inverter board
But there is a possibility that you could order the inverter board and have it turn out to be the bulb and if that is the case then unless you are very comfortable taking apart laptops then maybe a new screen would be best since you practically have to take apart the LCD to change the bulb.
But screen cost around 100 to 150 on eBay so if you decide to do that then might as well try for a deal like this: (I just spotted this on eBay and it is for entire new top half of laptop with glossy screen and inverter board wire harness and all for the same price or less than just the screen http://cgi.ebay.com/HP-dv1000-Pavilion-14-1-BrightView-Glossy-LCD-screen_W0QQitemZ310102538774QQihZ021QQcategoryZ31569QQssPageNameZWD1VQQrdZ1QQcmdZViewItem#ebayphotohosting
That is guaranteed to solve your problem for sure.
Posted on Nov 25, 2008
SOURCE: WONT BOOT BLACK SCREEN
this is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
Posted on May 22, 2009
fullyfuntime
  • 33 Answers
SOURCE: Screen stays black
There is few reason. Either your one of RAM is defective. Try both memory one by one. Even though if U don't see screen than its time to change motherboard.
Posted on Jul 22, 2009
bhagyavichar
  • 414 Answers
SOURCE: laptop turns on but screen stays black
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
..plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
for any further assistance u may plz leave comment and or testimonials at any point of time, so that i/we can help or u think it to b helpful..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 23, 2009
Hp entertaiment pc problem display STAYS BLACK BUT ALL LIGHTS COME ON
If the Video Controller fails, the screen will stay black when the rest of the computer runs as it should. To test this, look to the side of the computer and locate the external Monitor attachment. It is a nine pin male outlet. Take a regular computer monitor and attach it to the connection and turn on the computer. If the Monitor acts like your normal LCD screen, then the main LCD screen is bad. If Neither the Monitor or LCD works, then the Video portion of the computer may be defective.
Apr 15, 2014 | HP Pavilion Entertainment tx2500 Tablet...
Laptop will come on just a black screen
There might be problem with your laptop hardware. On excessive heating VGA chip on motherboard gives same problem. Get it checked with some hardware professional.
Feb 13, 2013 | HEWLETT-PACKARD HP Pavilion DM32010US...
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Screen blacked out laptop hp pavillion dv9404nr
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Jan 10, 2010 | HP Pavilion dv9000t Notebook
I turned my HP Pavilion 9000 series off last night and this morning I woke up to find all the lights on, the screen black and the indicator for the wireless internet showing orange instead of blue (it had...
Unplug the unit, and remove the battery. This will shut the machine off completely. You do not need to let the battery die out. Then power the unit on again. If the issue is gone, consider turning off hibernation ( power options inside control panel)
Sep 01, 2009 | HP Pavilion dv9000z Notebook
Screen stays black
Jul 21, 2009 | HP Pavilion dv9700t Notebook PC
Hp dv6000 black screen problem
tipical hp problem, if no warranty buy a new laptop "not hp", its called "the good old fashion hp graphic chip burned"
Jul 02, 2009 | HP Pavilion dv6000z Notebook
Lights turn on when starting up but screen stays black
Reboot and hold down the delete key to open the bios. Reset the bios to default settings then see if that fixes it. If not you may have to reload the computer to its factory load.
Mar 01, 2009 | HP Pavilion dv9000z Notebook
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion ze4935wm PC Notebook Logo
123 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
