Question about Samsung RB2155 Bottom Freezer Refrigerator
Code FD nothing works displays code FD sometimes starts working by itself i already replace the the main board
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: my samsung steam washer is displaying nothing. I have replaced main controlboard and display board and still nothing. Iwhat does the trans -reactorv do , ould this prevent the display from working. I
se this causes, and fix it. otherwise you must call some tech professional. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Posted on Sep 23, 2012
  • 2826 Answers
SOURCE: Samsung TV made really loud boom, now won't work
Yes, power board would be next.
Posted on Jul 16, 2015
A le-24g90 tv sometimes display ok sometimes black, tested capacitors are ok, when black front panel seems to work fine
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 04, 2016 | Seiki Televison & Video
Have a samsung refrigerator model rb1955sw will not turn on no lights, fan, or compressor just FD in the front display
I think you might need to replace it and if you still have a reciet that could be usful or they might fix it just call up the store
Mar 25, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Machine - Zanussi ZKG7125 The digital display has
Possible that the processor has failed and you might be in for an expensive repair. It is possible that the main board needs to be replaced. Remove the card and check for loose joints or moisture in the circuit.Dry and refit the board, if not you might need to check for replacing the board
Aug 02, 2013 | Zanussi Washing Machines
I have a sumsung SMH9151s microwave that recently started having problems. Now it keeps beeping and in the display its going back and forth to the letter L and back to 0. I tried unplugging it and plugging...
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Jan 11, 2013 | Samsung SMH9151 Microwave Oven
My oven display dosent work nor the oven itself it justs beeps and then nothing
greetings,
The membrane or main board has failed most likely. the display itself is built in the board...the beep usually follows some sort of fault code...its possible your having a voltage problem, like a burnt wire on L1 or L2 at the junction box or inside the oven itself. This is not easy to trouble shoot with limited info, but hope this gives you a general idea of what to look for...Bruce Denton
Dec 13, 2010 | Whirlpool RBD275PD Electric Double Oven
It does not start up and have already replaced the control board
Beffore the control board was replaced it was important to check that the power supply was correct. Hope the secondary/main transformer is working.if supply is not coming to the main board check the fuse and this sub transformer.
A check will indicate that the line is correct and the power comes to the board. If the board is not acitve then the front panel touch board could be faulty. Also check the main capacitor for the magnetron to function or the magnetron itself..
Hope you try this out.
Aug 25, 2010 | Microwave Ovens
U61 ERROR ON DISPLAY
U-61 is a hardware error code. Usually means main board failure, however have found that a bad changer can also trigger that code since it connects directly to the main board.
Sep 21, 2009 | Panasonic DMR-ES35VS
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
1997 isuzu trooper p300 code keeps returning
did you unplug the battery when the work was been done allowing the car main cpu system to reset itself if not u may have to go to a dealer of your car to have them reset cuz car computer doesent know work was done
Jun 05, 2009 | 1997 Isuzu Trooper
Samsung RB2155 Bottom Freezer Refrigerator Logo
32 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
