Question about Mitsubishi VS-5059 50" Rear Projection Television
Mitsubishi VS-5059 The red blue and green pictures on my set are not alligned. Of course it's nothing I can fix by aligning the crosses in the set up menu. If I open the bottom glass and hit underneath the screen it will fix itself (risking more damage). This has been going on for the better part of six months. A few of those months it did not mess up at all. I've had this unit fixed one time prior because the picture woul go out entirely but that has not happened. I've heard that it may be the cold solders on the convergence panel? I'm pretty decent with a soldering iron but I have no idea what I'm looking for and I'd rather not cause more harm if I don't know for sure. Please help.
Ic stk392 110 replase chak resistors 2.2ohm
Posted on Feb 21, 2008
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
The color seems to be out of alignment. Is this an alignment problem or an electronic problem?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Cannot reset vertical convergance
*Screen Looks 3-D
*Colors wont align
Problem #2
Mar 16, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi VS-50501A convergence problem. The image looks like a bow tie and the convergence will not align. This TV only has manual convergence. I already replace the STK391-020 ICs, it has 3 of them....
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 15, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50705 50 in apparent convergence problem.
First thing a tech would do is solder around Convergence amps then check to see if you can align by menu then if can not. Change amps and maybe resistors.
May 19, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-55609
Can anyone tell me where the horizontal driver xformer is on the VS-5059?
Oct 23, 2007 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Oct 01, 2007 | Mitsubishi VS-50502 50" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
