Question about Water Sport
1990 yamaha waverunner 650d - Water Sport
2 Suggested Answers
finish line
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
Yamaha torque specs
The owners manual does not provide torque specs there is an on-line manual for $5 which claims to cover torque specs at: https://www.tradebit.com/filedetail.php/141315359-yamaha-waverunner-gp1200r-service-manual-repair-2000-2002
Jul 05, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
What is the size and year model of my yamaha waverunner the hull id # yama31321394
Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
May 29, 2014 | Yamaha Boating
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
1989 yamaha waverunner. I purchased a 1989 25HP Yamaha Waverunner & was wondering how you check the engine oil?
Did you get any instructions from the previous owner? If it's a 4 stroke waverunner there will be a dipstick on the engine block, but I'm guessing it's probably a 2 stroke engine because most watercraft used 2 stroke motors clear through the 1990's. The oil will be mixed with the gasoline when you fill it, bottles of 2 stroke oil can be purchased at most stores that carry oil. Your waverunner can be mixed at 50:1, which equals out to be 2.6 oz of oil per gallon of gasoline. On a 2 stroke engine the engine gets lubrication from the oil mixed with fuel and will burn up fast if straight gasoline is used. Let me know if you have any troubles, but try to get ahold of the previous owner to get some more info.
Daniel
Aug 12, 2011 | Yamaha Superbike 1098 R Motorcycles
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
I have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
Sep 29, 2009 | Boating
How do I reset the code on a yamaha waverunner
How do I reset the code on dash board 99 yamaha waverunner 800?
Aug 02, 2009 | Sport & Outdoor - Others
Yamaha waverunner excessive smoke
White smoke means coolant in the combustion chamber. Most likely a blown head gasket. You will have to tear the engine apart to be sure.
Jul 12, 2009 | Yamaha XS 650 G Motorcycles
May 15, 2009 | Yamaha 12V Air Pump
Water Sport Logo
32 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
