Question about Refrigerators
Msd2754gr light will not go off after filter was replaced
  • Refrigerators Master
  • 4,654 Answers
To reset the Change Filter Light: Press and hold the Light and Lock pads until the Change Filter light blinks (approx
3 seconds) The control is now reset for 12 months or 416 gallons. I will be here should you have questions, Thanks Sea Breeze
Page 12 in the MSD2754GR User Manual gives the above instructions.
Posted on May 10, 2013
Where is the thermostat on a maytag MSD2754GR refrigerator
It will be directly behind the knob marked refrigerator... Maytag Refrigerator Temperature Control Thermostat WP61005651
The knob literally mounts on the thermostat.
Jun 20, 2016 | Maytag Refrigerators
Maytag msd2754gr Not cooling.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 23, 2011 | Refrigerators
Maytag side/side model MSD2754GR- Ice maker while filling overflows running out of freezer section onto floor.
Remove the back panal in the freezer compatment to reveal the evaporator. You will notice the drain pan frozen up with ice. pour hot water on it or blow hot air with a hair drier. If the fridge is turned off the ice will melt and clear the drain hole. When the ice is cleared the water will be alowed to flow out to the evaporating pan under the fridge. Be sure that the water runs freely out of the fridge and allow a few hours to dry. Good luck. Be careful not to damage the evaporating coils.
Dec 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag model # MSD2754GR the refrigerator leaks
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilsh
Nov 30, 2009 | Heating & Cooling
Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Aug 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Model MSD2754GR Side-by-side.. it will dispense water but will not fill the ice trays (I have checked all the obvious stuff, water supply lines and ice sensor arm). Don't here the control module "clicking"...
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 11, 2009 | Refrigerators
I have a maytag MSD2754GR, the freezer bottom is all iced
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
It took me about 20 minutes to do this.
Hope this helps.
Jun 22, 2009 | Maytag MSD2456G Side by Side Refrigerator
Water leaking from the hinged side of the freezer door at the bottom. Not continous, seems to be tied in with the defrost cycle. Ice forming in bottom of freezer. Model # MSD2754GR
If you open the freezer door and remove the bottom basket, there will be a small shelf with a hole in it, if it is covered with ice the drain is most likely plugged. hopefully you can remove the ice with a hair dryer and run some hot water down and clear it. If not you may have to go in from the back and remove the drain tube. this is a serious pain in the ***.
Jun 19, 2009 | Refrigerators
Maytag Model MSD2754GR* In-door ice dispenser assembly
could be the micro switch your not very clear on the promblem
Dec 29, 2007 | Washing Machines
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
