Question about Lexmark T644dtn Printer
900.56 service RIP software error
Replaced system board and no change. Problem is intermittent. Powering off/on clears and printer may print rest of day. Several users experiance it from different work stations.
NotAsUsual
  • 43 Answers
SOURCE: 900.00 Service
When I have seen this error in the field, I have cured it by updating the firmware. Lexmark has a paper in their Knowledge Base on 900 errors:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:556:0:0&framed=&docid=ENUS22164&relevance=1
Go through the suggested steps to try to narrow the problem down.
But if it needs a firmware update:
http://support.lexmark.com/printerfirmware/
Use code: Isfap129 to download the package the C530dn.
Hope this helps!
Posted on Dec 01, 2007
SOURCE: Lexmark t642
I too ran into this problem. Printer is about 2-1/2 yrs old.
Using it as a network device. I updated firmware from
a Mac OS X computer on the network.
a. Uploaded the firmware by going to lexmark site.
Do this first in preparation of upgrading firmware.
Follow instructions to get firmware update.
b. power cycle the printer (turn off & unplug power from unit)
c. power printer and turn switch back ON.
happily printer stays alive long enough to upload the new
firmware update.
d. Log on to your printer via a computer on your network
Open a browser, address will be your printer's IP address
or dns name. ex: http://192.168.1.3 (note: if you password
protected the account, you will need that info)
e. Follow menu to Configure -> Update Code where you will
"browse" to the file on your local computer (ex:
LSSTN234.FLX) and then hit the FLASH button
Posted on Feb 08, 2008
SOURCE: 900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
Posted on May 24, 2009
SOURCE: 910 service engine + 900 service RIP software
931 service
Posted on Jul 09, 2009
Mrinny
  • 94 Answers
SOURCE: What does 900 Service RIP Software error message
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Posted on Aug 02, 2010
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
what is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
Aug 14, 2008 | Lexmark Office Equipment & Supplies
Error 900.44 .... RIP Software
The error relates to the system board / formatter.
R.I.P = Rest in Peace
Turn off machine for 10 minutes.
If error persists follow theses steps:
1. ) If the machine is networked disconnect the cable and power cycle. If the error doesn't come back up swap the network cable, with a good one.
2.) Firmware upgrade
3.) Replace the system board
Based on my experience it's either the network cable or the system board.
Oct 15, 2010 | Lexmark T642 Laser Printer
What does 900 Service RIP Software error message mean and how do i reslove it
    4. Press Select.
Aug 02, 2010 | Lexmark Optra T610 Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
Lexmark C510 not printing - message 900 service RIP software
Hi, This error could be due to several things, the most common one is that whatever is being sent from the computer is not being recognized by the printer causing the 900 Rip Soft Error. You can try to reset the printer and try sending the print job again. If the error persisted. Then the problem could be a hardware problem with the System Board.
Jan 13, 2010 | Lexmark C510 Laser Printer
I have a problem with t644 indicated 900.00 service rip software before this error printer indicated 960 service.after turn printer off then on error code indicated immediatly
Try this...power off printer. Then if it is a network printer go the to print server and clear all the documents from the print cue. If it is a local printer clear all documents in the local print cue then power the printer back on. Once the printer powers up the error should clear, if it doesn't clear power the unit back off and ensure that all documents have been removed from the print cue then power printer back on. This worked for me on the C782e, x854e and x940e models that I have.
Jul 04, 2009 | Lexmark T644 Laser Printer
NO ERRORS......
May 24, 2009 | Lexmark C750n Laser Printer
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
May 04, 2009 | Dell Office Equipment & Supplies
1,468 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
