Question about Samsung HT-DB600 System
DVD stuck in player
Have a DVD stuck inside the palyer. Even the tray is empty when I open it? How can I remove it?
Samsung dvd-9800, no power, dvd and vcr tape stuck in player, how do i get it out? thx!
Posted on Jun 17, 2010
Take top piece of the dvd player. there are about 7 screws.  5 min fix
Posted on Oct 27, 2007
SOURCE:
The disc is stuck up in dvd player how can i open it up to remove the disc thanks
Remove DVD player from the mains. Look for the slotted opening covered with plastic cover at the bottom front, which can be opened easily by hand without much force. After opening it put a small flat screwdriver (locate the stud inside) & move it so that the tray will just open. Then pull the tray & remove your CD.
Aug 13, 2011 | Philips DVP3982 DVD Player
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
My dvd player is dead on my sa ht670 panasonic dvd player home theater. Is there any way to still use the other functions like aux? i do no need the dvd player just want to use the theater for sound. I...
Maybe if you ask it to OPEN the tray as soon as you turn it on and leave it that way it might move on to other functions. A hands-on tech would have to lay hands and eyes on it otherwise.
Jul 04, 2011 | Panasonic SC-HT670 System
Dvd is stuck inside and drawer will not open
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
Dec 02, 2009 | Philips Televison & Video
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
A DVD is stuck in my player. When I open the tray the dvd isn't in it. I can see the dvd inside the player but it will not drop on to the tray. HELP! ITS A RENTED DVD!
Try removing the top cover, very often if the DVD is not in the tray it will be accessible to retrieve once the cover is removed.
Aug 04, 2009 | Toshiba SD-2900 DVD Player
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Upon trying to remove a disk, disk remains in player and tray opens empty
This is caused be the "lift" part of the mechanism not functioning properly. A fix may be inexpensive or not, depending upon what is needed to make it rise and lower properly....accordianman
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Samsung HT-DB600 System Logo
1,516 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
