Question about Briggs & Stratton Garden
Its back firing and keeps cutting off cleaned the filter
  • 20 Answers
Hi: Did you hit a rock or other solid object ,Some times if you hit a hard object it will Shear or partly move the Flywheel Key and throws the timing off which will cause kick back and back firing. If it is back firing through the carburetor it is probably flooding cause by a dirty or faulty fuel jet and seat, if so clean and check the jet in the carburetor. Hope I have helped you AL
Posted on Apr 07, 2014
Can the charging system on a 2004 polaris ranger cause back firing cutting out and dying
these ATVs do a lot of hard work for size of motor
worth checking other things as per normal servicing
new spark plug
clean air filter
drain and add new fuel to tank
wont hurt to clean the carby or bowl contents
if fitted with a fuel filter inline .. fit a new one
and valves adjustment if still back firing
Oct 13, 2016 | ATVs
Why does my 2002 chryser voyager keeps cutting off and back fires
Any codes,tune up,fuel filter,could be crankshaft sensor.
Aug 20, 2014 | 2002 Chrysler Voyager
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Thermal cut-off
when the thermal fuse or the high limit pops it's because the dryer is running to hot,all a dryer does is move air,when one of the fuses pops it's from a block from lint either in the lint filter duct or the vent line,if the air can't blow outside or out of the dryer the fuse will blow.if your vent line is long remove it from the back of dryer and stick a leaf blower into the vent line and blow all the lint outside,make sure there isn't a cage or anything blocking the outside hood,then pull out the lint filter,take the dryer apart,remove the lint filter duct and clean it out,also vac and blow out the cabinet and motor,you should do this once a year,your clothes will dry on time,less parts will get damaged from overheating ,your electric bill will be less and most important you won't have a dryer fire.hope this helps,the fuse will keep blowing until you clean out the dryer and vent line.
May 16, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
Stalling 22r 1983 toyota truck 22r fires up, runs great then cuts out. fuel bowl goes empty and i've replaced everything, pump, filters and cleaned tank
Check the steel fuel line under the intake manifold
had one that was almost completely clogged shut with ****
took a month of hunting but found this to be the problem
May 16, 2012 | 1983 Toyota Pickup
My Rheem furnace fires up but the fire keeps cutting
Hi check out the pressure switch ,jump it out see if it fires clean flame senser if fitted, clean airfilter check fan afc is clean might be dusty
Feb 02, 2010 | Heating & Cooling
Abs fault light on ,fault finder keeps flashing
you will find that its a faulty actuator common fault.somtimes its the front somtimes it the rear they are costly buy a manual on disc from ebay and go though the checks.
Oct 01, 2009 | 1991 Honda ST 1100 Pan European
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
