Question about Sharp Office Equipment & Supplies
Bypass tray problem
MX-c311. I'm trying to print to legal that we keep in the bypass tray. As far as I know, I've set every setting on the machine to Legal, and in my print settings when I go to print, even identifying using the bypass tray. It errors every time. Help.
    New Friend:
  • 16 Answers
What error does the machine display?
Posted on May 09, 2013
  • 62 Answers
SOURCE: Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Posted on Oct 05, 2007
  • 126 Answers
SOURCE: Printer always prints from bypass tray...
Check the setting in / on your computer. Make sure it is not set to default to the bypass tray.
Posted on Jan 08, 2009
SOURCE: Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Posted on Feb 18, 2009
tehnik_bdg
  • 91 Answers
SOURCE: sharp mx 3500 won't recognize custom paper
In the printing properties, on the paper select tab, change the paper tray from automatic to by pass tray
Posted on Jun 23, 2009
djuksoni
  • 103 Answers
SOURCE: Change default tray for E-studio 520
go to Control panel, select printers and faxes (windows XP),then select es520,right click properties, select Tab advanced,then you should click on printing defaults. then will open toshiba driver defaults,go to paper handling tab. THERE IS option called "destination" and there you can chose exit tray (inner,tray1,tray2...etc). After selection you must click apply and then ok. and that it. every time after that documents will be printed out to selected tray.
Posted on Dec 07, 2009
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Aug 03, 2012 | Sharp MX-2300N Color Copier
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
Will not double sided print as book
Sorry unfortunately I can not figure out what is going wrong here. It could be the way MS word is sending the document to the printer, the only thing I can think of is that it may be that you do not have the page setup of the document set to legal. There may be something in word that also allows you to send the document to the bypass tray as opposed to the default tray.
Nov 29, 2011 | Toshiba e-Studio 200 All-In-One Laser...
Can I print A3 size through the bypass tray
Is that Legal sized paper? You should be able to as long as you pull out the bypass tray sections so it can detect the size.
Sep 14, 2011 | Sharp MX-2300N Color Copier
How do you load standard sized envelopes into a Sharp MX-2300 copier?
Use the Bypass tray to load it. But first try the paper tray and try to load it there and see if the paper tabs have a size adjustment for envelopes. If not try the by pass
Apr 10, 2010 | Sharp MX-2300N Color Copier
Sharp mx 3500 won't recognize custom paper
Jun 19, 2009 | Sharp MX-2700N Color Copier
Envelope printing
Go to custom setting, paper size setting for by pass tray, use custom measurement,input the size of the envelopes ( in X Y mode ). When you print, go to the properties and change the paper tray select from auto to by pass tray.
Good luck.
Mar 11, 2009 | Sharp MX-2300N Color Copier
4250 printing problem
Make sure you have the paper tray guides pushed up far enough.
Print a configuration page by the printer panel and verify the tray settings are correct. If they differ, check the fences are pushed up and ensure the tray lever is set to STANDARD not to CUSTOM.
If the printed paper tray settings differ to what is actually set, you may have a faulty paper tray width sensor. If you still have trouble try the Restore Factory Settings Option. Remember to note any IP info if the unit is attached to a network.
Nov 09, 2007 | HP LaserJet 4250dtn Printer
122 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
