Question about Mitsubishi Televison & Video
Mitsubishi tv repair
I have a 60inch mitsubishi tv an the sound keeps going in an out what can i do?
I have a Mitsubishi 60inch 60737 replaced the bulb last month.now it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
May 27, 2015 | Mitsubishi Televison & Video
Blue spots on screen
Most likely the LCD panel is failing. These are "stuck pixels". Common with early LCD displays used on DLP TVs.
Jan 22, 2014 | Mitsubishi 60inch 3-D Ready 1080p 120Hz...
I have a 60inch 1080p big screen Mitsubishi tv with atleast a 1000 little white spots and tv turns off frequently when 1st turned on what is wrong?
The white spots sound like the Optical Light engine has a bad display, they sometimes start with one or two and multiply.
The engine is about the most expensive part in the set, see attached photo of one
Dec 21, 2012 | Televison & Video
My 60inch phillips hdtv won't turn on and i can
This problems,cause by the 2 STK dead convergence too.U must have soldering tools,solders and must Know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop cost u $300-350 for parts and labors.
May 07, 2010 | Televison & Video
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Rca no picture no sound
There is no sound on my rca 60 tv. what can I do. The movel number is P60921.
Jul 30, 2008 | Televison & Video
TV problems
I have a mitsubishi HDTV 1080 Integrated and the speakers are off and I can't get it back on
May 14, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
1995 mitsubishi 60inch big screen
Probably a solder issue. try soldering around the flyback, line coilsand vertical and yoke plugs. You can get a service manual for 10.99 emailed to you at the following link. they also offer free support to help with the diagnosis of your Set.
http://servicemanuals.vstore.ca/
Feb 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
