Question about GE FUF17SVRWW Upright Freezer
Ge freezer control board recall
Control board
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Refrigerator GTH18IBXWW Control panel lights not illuminated (refrig and freezer settings and read out). This after a power outage.
Unplug it and see if it resets after you wait 5 minutes and plug it back in. If the outage was caused by a surge, it may have damaged the control board.
Dec 22, 2015 | GE 18.0 Cu. Ft. White Top-Freezer...
Is there a recall on control board?
That is usually a signal meaning the door switch is being sensed as open... Make sure the light goes off when you press the switch, if it does, buy a new control... OR remove the control and break the little round speaker off of the board to quiet that thing.
Aug 06, 2014 | Frigidaire Freezers
Frigidaire freezer M# ffu17f5hwh, is there a recall on control board?
Hello friend, thanks for the post!
I see that the red light stays on and your Frigidaire freezer continues to beep. From what I have researched there is no recall on the control board of FFU17F5HWH. You could try resetting your appliance, which could be done by unplugging the power cord or flipping the household circuit breaker in the off position for ten minutes. Please comment back I would like to know if this information has been helpful. I look forward to your post. -Matt
Aug 06, 2014 | Frigidaire FFU17F5H Upright Freezer
Numerous problems with upright ge freezer fuf14svarww. Most of the time the same problem occurs. The freezer display will be blank and the freezer simply is not operating. If power is disconnected then...
I believe it is the=>WR55X11084 Main Control Board
There is not much there other than the overload and start relay that if they malfunction it will be a possible to overload the electronic components on the WR55X11084 Main Control Board so I would begin by replacing the main board first. If you notice problems with the compressor starting then replace the start components, Thanks John Tripp John Tripp Appliance 911
Mar 04, 2014 | GE FUF14SVRWW Upright Freezer
My GE FUF14SVRWW upright freezer will shut off for no reason. The digital temperature control will be blank, the light will not turn on, and freezer isn't running. I will unplug it for a few minutes and...
Ach, digital controls! It sounds like the logic board/panel is on the fritz. No cure unless you can identify the malfunctioning component and replace it.
Nov 05, 2013 | GE FUF14SVRWW Upright Freezer
Reset ge refrigerator
The electronic control board can be reset by unplugging refrigerator and waiting five minutes and replug electrical power to refrigerator. What are you wanting to reset on your model? What is the correct model number for your freezer/refrigerator? Tell me just what you are trying to reset and why? So I can help you better, Thanks Sea Breeze
Mar 31, 2013 | GE GTS18EBDWW 18.1 Cu Ft White Top Freezer...
Clicking noise in the circuit board and everything in the freezer is thawed
Hi. this will be a failed relay on that circuit board. This is called the PCB(main unit power control board). This board controls the compressor relay functions, and the compressor power current, as well. The evaporator fan, and condenser fan, receives their respective current from this power control board, also. When a circuit board of this nature begins to malfunction, it will cause the unit to not cool properly, due to limited, or no fan actions, or a failed compressor cycle. I would recommend to replace this damaged control board, asap.
Dec 04, 2009 | GE Freezers
Need to find the defrost timer
The defrost control is integrated into the main circuit board on the rear of the fridge.
You have to change the complete board.
May 23, 2009 | GE Freezers
GE FUF17SVRWW Upright Freezer Logo
80 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
