Question about Hardware & Accessories
Z timer Model PET-009
I need manual to program timer
  • 5,245 Answers
Copy following link to identify timer and download possible manual for PET-009 timer
http://waterheatertimer.org/How-to-program-and-wire-PET-009-Timer.html
Add a comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 09, 2013
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
How to program model E257484
This model number does not show valid search results.
Following link has manuals for many outdoor timers;
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Gene
Water Heater Timers Save Money
Dec 17, 2014 | Hardware & Accessories
Im looking for a english manual
I use Google-translate to translate manuals.
Description or model number of timer would be handy for more detailed effort finding manual in English.
I have manuals for European countries: Hagar and Gardena.
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
I also have manuals for other timers, that may be similar to your timer, and same instructions will work.
Nov 03, 2012 | Hardware & Accessories
I have a timer model TN004000 I need to know how to program it.
Thank you for including the link.
There are two timers with that same basic design.
I cannot find a manual for the older style.
The newer style is made by Tork and sold under several brand names and product numbers.
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#13660
Aug 25, 2012 | Hardware & Accessories
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I need to find instructions for my westinghouse timer model 28499 directions
Hello I made a couple of videos showing how to first set the time and day and then how to program this Westinghouse model 28499 3 outlet photocell timer.
Nov 30, 2010 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 11, 2010 | Maytag Refrigerators
Hardware & Accessories Logo
669 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
