Question about Denon AVR-1507 Receiver
Denon 1507 The receiver turns off after a few seconds. which component does typically ruin?
SOURCE:
  • 277 Answers
SOURCE: denon avr 1601
hi there many things that can cause this fault main reason: the device is in protective mode and wont let anything to happen to the reciver and its components - the amp is shorted - its heating up - short in the voltage regulator - and many more..... my advice....: if its in warranty then fix it if u understand what i just wrote then open it up and look for the problem and if neither of these are relevent.... then just take to somebody that does good luck windman
Posted on Feb 14, 2006
  • 3 Answers
SOURCE: Power won't stay on
This could be a major problem in the power transistors or closely related. Recommend service by a technician
Posted on Jun 02, 2008
  • 151 Answers
SOURCE: Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Posted on Jul 12, 2008
mattvierra
  • 74 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
  • 4 Answers
SOURCE: Receiver turns off in a few secondsafter switching on
read in the manual and reset the system. if it still doesnt turn on, then it has to be taken in for repair. same thing happened to mine
Posted on Aug 01, 2009
How do you connect denon avr 1507 to pc? hav used rca but does not register on pc
you should be able to use a rca to mini-plug cable and hook up to the audio out or headphone jack on your pc
Jan 08, 2014 | Denon AVR-1507 Receiver
Denon AVR-1507 speakers don'twork is there something I can reset
Yup, don't guess, read. Lots of things to set.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1507-Receivers-manual/id/696ci071/t/2/
Mar 14, 2011 | Denon AVR-1507 Receiver
My Denon AVR-1507 keeps automatically turning off every time I turn it on. Then the standby button blinks red. Is there a quick fix to reset the microprocessor?
Hi
Thanks for using FixYa. Store these instructions in a safe place. After reading, store these instructions along with the warranty card in a safe place. Whenever the power operation button is in the STANDBY state, the unit is still connected to AC line voltage. Please be sure to turn off the power operation button or unplug the cord when you leave home for, say, a vacation. Note that the illustrations in these instructions may differ from the actual unit for explanation purposes. Please click on this link for further reference---
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | Denon Audio Players & Recorders
No bass from speakers
go in to your settings an adjust the bass volume
Feb 17, 2009 | Denon AVR-1507 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Power won't stay on
Apr 19, 2008 | Denon AVR-1507 Receiver
Problems with Ext ins staying on
Check your user manual. Many Denon receivers have a reset function that returns every thing to the default factory settings. If you still can't change the input, professional service will be required.
Sep 18, 2007 | Denon AVR-1507 Receiver
Denon avr 1507 no power
look at power supply and see if blown fuses first and then check for any open resistors.
Sep 14, 2007 | Denon AVR-1507 Receiver
Connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
Jul 01, 2007 | Denon AVR-1507 Receiver
Denon AVR-1507 Receiver Logo
19 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
