Question about Asrock 775i65G Motherboard
MY MOTHER BOARD DOSE NOT LOAD WINDOWS WHEREVER I TRY IT HUNGS AND SOME TIMES IT FAILS TO DISPLAY
  • 32,281 Answers
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on May 09, 2013
Sony vaio pcg 71212m no display and no power
No display, no power. Must be no computer!
try this: Check battery, power connections.
If fails, could be mother board issue.
Sep 09, 2013 | Computers & Internet
My computer will not boot up,mother board problem?
could be a mother board problem but before you replace it try a few things first
remove the memory and try to boot
unplug all hard drives apart from master and try to boot
go into the bios and load default settings rty to boot
when you mean doesnt boot do you get the welcome screen ? says windows xp etc
if so then its a windows issue and you need to reinstall windows
if after trying all of this the yes maybe its a mother board issue
hope this helps
John
Jul 07, 2011 | Intel Computers & Internet
My computer power turns on but the screen is black no activity is happening
plz try by resiting the ram. if the problem is not solved then remove the system battery from the mother board and wait for 20 seconds and boot the computer. if all the above steps fails to bring up the display then *********** board is to be changed.
Aug 23, 2010 | Acer Computers & Internet
My windows vista has no audio device indtalled how can I fix it?
Hi the problem you are having is with the drivers for the mother board what you need to do is find out what the main board is in your computer their should be a printed part on the mother board that tells you what mother board you have then using google type in drivers for (enter make and model of mother board here then press enter)
then download the latest drivers for *********** board and install them this will get the sound working again
Aug 14, 2010 | Microsoft Windows Vista Ultimate Edition
Asrock 775i65G motherboard when i install widows xp can't continue, and hungs when setup windows excutive load,,how i fix this problem pls help me
Try installing Windows in a directory other than Windows. Let it be installed in say WINXP or whatever name you like.
Jan 13, 2010 | Asrock 4CoreDual-SATA2 Motherboard
Mother Board Display Problem
Hi, i think its a vga card or onboard card, if not make sure that you ram is tight and if u can get a dust blower and blow it, and just make sure that before u close it, u quiz in tight all the attached components on the mother board, if it refuse, then get another graphics card and try a gain.For starts u can use a very cheap Pci vga card and or AGP card. The other thing that i want u to take not of is try some friends monitor and see if it works if it fails then try the first option. However usually intel has a beep code, take not of the beep code and tell us how many times the it beep.
Hope u are help.
Cheers
Apr 27, 2009 | Intel D845GVFN Motherboard
My P5VDC-MX Asus motherboard are not supporting graphics.
The builf in graphics are not the best. Your best solution is to invest in a good graphics card & disable the onboard video in bios. Hope this helps.
Mar 20, 2009 | ASUS P5VDC-MX Motherboard
Motherboard problem
Hi ,
You check cpu fan on motherboard ,even it is fitted tightly pl check the motherboard back side, even it is some loose hanging problem will occur.
And check the Hdd power connector also it is tighten or not.
and u also reinstall the o.s
Pl try it
Was this soultoin useful ?show ur appericiation for it
Mar 21, 2008 | Intel D915GAV Motherboard
Asrock 775i65G Motherboard Logo
21 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
