Question about Mitsubishi WD-60735 Projection Television
Mitsubishi tv can't get it tostop from burning blubs
Can hear sound but all you see is lines on the tv cant see picture
your blub probably burned out. you'll need to get it replaced.
May 02, 2011 | Toshiba 65H82 65" Rear Projection...
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
Put in new blub and heard a zapping sound is bulb bad or tv?
Check the bulb is not damaged and is inserted fully into the socket. The bulb needs several thousand volts to ignite which would be the sparking noise you heard if not connected properly.
Mar 08, 2011 | Mitsubishi WD-52526 LCD TV
Screen resembles 3D look with predoment red and green to images - did the blue blub burn out and need to be replaced?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.By replacing all these parts on the tv convergence board to fixed it to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 05, 2011 | Mitsubishi VS-60803 60" Rear Projection...
Light does not turn green lights come on fan
Try another blub and check to make sure the cover for the blub is on and the liltte switch is being triggerd by the cover to tell the unite the blub cover is on. Kinda like on a washing machine. Good Luck
Feb 18, 2010 | Mitsubishi SL1U Multimedia Projector
2 red lights on, no blinking. And no bulb on is the bulb burned out?
i think ur sytem in stand by mode / pcb complaint related to microcontroller.
May 27, 2009 | Mitsubishi XL8U Multimedia Projector
Mitsubitshi wd 52725
Good Day;
From you said you should call a Factory Authorized Service Center, toooo many problems with TV for non-tech person.
Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
REPLACING LAMP
You will have to extract the old lamp and utilize that original part to make this repair...accordianman
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WD-60735 Projection Television Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
