Question about Sunbeam Vintage Chrome Mixmaster Mixer Mmb
How to replace brushes on a mmb mixer - Sunbeam Vintage Chrome Mixmaster Mixer Mmb
Need handle replacement and power cord for sunbeam mixmaster mmb
NelsonEZY.com stocks the power cords. The handle should be available on eBay. NelsonEZY com home page
Mar 22, 2014 | Sunbeam Vintage Chrome Mixmaster Mixer Mmb
Replaced phase and speed control board and mixer still doesn't work! Bad words are flying around here tonight!
Michelle,
Have you taken the brushes out of the mixer at any point? I see quite often people remove the brushes, and then they are inserted incorrectly when put back in, the brushes will fit in in any direction, but there is only one way to put the brushes in properly.
when you look at the brush, the carbon portion is square with one side cut off, the brush holder inside the mixer is shapped the same way. use a flash light to match up the brush, after installed correctly the mixer should turn on and function correctly.
If it does not then you should call into us, when around your mixer and we can do more trouble shooting over the phone.
Thank you,
Colleen
The Mending Shed
801-225-8012
Mar 20, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
My KitchenAid KSM90 will not turn on at all.
First make sure that the mixer is plugged into a working outlet. Were there any symptoms the last time you used your mixer? Check the cord on the mixer for damage. If the cord shows any wear replace it immediately.
At any point in time have you removed the brushes or adjust the speed control plate? After checking the cord, remove the brushes from the mixer, check to see if they are pitted, if they are replace the brushes. Please pay extra attention when putting the brushes back in the mixer, there is a dog-eared side of the brush, match this up to the brush holder to make sure the brush is inserted correctly.
If the brushes are not the problem check the speed control plate. If you remove the end cover from the mixer you can gain direct access to the speed control plate. There are 3 screws on this plate, the top two are used to adjust the speed of the mixer, the bottom one spaces the on/off switch contact. Try adjust the bottom screw to see if the mixer will turn on, it is possible the on/off switch was out of place.
Try these first, if none of this works let me know and we can continue trouble shooting.
Here is a link to the cord for your mixer: http://www.mendingshed.com/mixercord2.html
Here is a link to the brushes: http://www.mendingshed.com/kitchenaidbrushes.html
Here is a link to the speed control plate: http://www.mendingshed.com/speedcontrol.html
And here is a link to the service manual for your mixer, it has more troubleshooting ideas on the last few pages: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
customerservice@mendingshed.com
800-339-9297
Apr 13, 2013 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer on my Sunbeam Model MX5900 compact mixmaster has burned out because beaters kept jambing in each other. Can I purchase just the mixer and beaters? Stand and bowl are OK
If the motors had burnt out then the winding can be redone if you can get this job to a winding shop.
Other wise the motor and assmebly can be ordered from a Sunbeam service outlet. try and see if you re able to source a motor assembly from a damaged/scrapped set with a mechanical defect.
Sep 20, 2011 | Sunbeam Food Mixers
I have a KitchenAid mixer Model K5SS, Ser #W83808959. The motor stopped running and in checking the brushes, I found they are are both stuck in the brush holders. I suspect this is the reason the motor...
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
You may have to remove the Motor Housing and use a small screwdiver
to completely remove the brushes or all portions of them if they are broken.
Jul 30, 2011 | KitchenAid K45SS Classic Stand Mixer
I just replaced worm wheel on my KitchenAid Stand Mixer. Power was working prior to worm wheel breakage. Mixer was running, but not spinning. Dismantled Mixer, and replaced worm wheel. Put back...
Check the carbon brushes, look inside the hole, it is keyed, the brushes only go in properly one way. Match the missing corner on the brush to the blocker inside the brush holder.
Sep 07, 2017 | KitchenAid Food Mixers
Won't turn on after first use. 1801 220 watts hand mixer looks like 2562 250 watt mixer
It seems that the mixer is overheating and tripping the thermostat thus preventing further use. I would recommend a thorough overhaul. You will need to carefully inspect all the components, particularly Items the brush assemblies, and the commutator portion of the armature (where the brushes touch the armature), and everywhere else in the motor compartment. Any parts exposed to oil will need to be degreased and dried before reassembly. When you reassemble your mixer, the brushes can only be installed one way. Make sure the brush's concave contact face is resting completely on the armature. If it is turned it 90 degrees too much, it wont' seat properly and the motor will not get any juice.
While your mixer's apart you should check for any other unseemly wear and tear on the gears, etc. You may find more things that need fixing, adjustment or replacement.
You may find it easier to replace the brushes than degreasing them. I recommend using a food-grade grease that you can order online (although I've seen automotive bearing grease used too - your call). If you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer.
Dec 12, 2010 | Sunbeam 2562 250 Watts Hand Mixer
Replacing the brush
Hi DENAULTR, this is a repeat of my previous answer to your problem. It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model. Turn to pages 6 & 7, titled ?Motor And Control Parts?, which provides an exploded view for the disassembly and reassembly of your mixer?s electrical components, along with all the part names and numbers. Locate Illus No 47, Brush holder assembly that includes Illus. Nos. #28, 32, 33, 34, & 46, and Illus. No. 29, Brush & Spring assembly respectively. Make sure you orient each bruch correctly following the illustration here: The Parts List diagrams along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA If this solution has been helpful to you, please rate it, thanks! -hslincoln
Feb 26, 2010 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
Jan 29, 2010 | Food Mixers
Kitchenaid mixer k45ss slow gear stopped working. Took out brushes and now when replace brushes mixer won't work at all
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
Apr 07, 2008 | KitchenAid K45SS Classic Stand Mixer
Sunbeam Vintage Chrome Mixmaster Mixer Mmb Logo
56 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
