Question about Activision Call of Duty 2 for Windows
Swiftshader 3 0
Mouse doesn't move
D3d9 download swiftshader
This is probably because the graphics card you used, did not meet the minumum requirements which are 128MB, Shader Model 3 and DirectX 9.0c compatible
SwiftShader
is now open sourced software that enables 3D rendering on systems that can't fully support hardware-accelerated rendering. http://blog.chromium.org/2016/06/universal-rendering-with-swiftshader.html
Jan 08, 2014 | Rainbow Six Vegas - PC Games
Mouse doesn't always connect
Mouse may be dying or the USB port needs update. If you can borrow a mouse or purchase a news one to test. If you need to update USB driver go online to see how to do that. I would bet IRS just the mouse.
Apr 25, 2017 | Logitech NX80 Cordless NB Mouse OEM
Mouse doesn't move cursor
if this a desktopcomputer.is the mouse wireless change batteries.if p/s2 try with aUSB mouse can be the driver.
Apr 06, 2013 | Sony VAIO VPC-J Series 21.5-Inch Black...
Mouse won't function at all
Buy a new one and see if that cures the problem.
Jun 05, 2017 | Dynex Computers & Internet
I cant unlock my mouse sensor..
If you can't unlock your mouse sensor then follow these instructions down below:
To make your mouse MOVE first you must
1.Put your mouse usb in your laptop in the usb holders
2.After you done, something should pop up a few seconds later near the bottom right hand side, saying usb mouse connected.
Try moving your mouse now.
if doesn't work:
go in the control panel ( you can find that in your window by pressing the window button on your key bored)
3.Then there should be a topic named " Hardware and sound" click the first topic called " view devices and printers"
4. After you clicked that there should be on the top on the page "Devices" and the bottom should be printers and faxes.
5 then you can double click the device to look if right one. DONE!
I hoped this worked! ^-^
Sep 29, 2012 | Acer Aspire 5102WLMi Notebook
My cursor on my HP doesn't work. don't want to use a mouse.
i'm sure that there's a button to lock the trackpad,it's near the panel.you need to press it once again to turn the panel on
I think it's right above the trackpad
or look on your laptops keyboard for a picture like trackpad press it with the function Fn button at the same time
or it should be the hardware
the trackpad cable maybe doesn't installed properly,not locked or something
Aug 20, 2012 | Computers & Internet
MOUSE WILL NOT WORK
You haven't said what kind of mouse you have or whether it used to work.
I'll offer some suggestions for the most common problems:
If it used to work but now doesn't, try a system restore back to when it did work.
If that doesn't work--are you using a wireless mouse? If so, are the batteries fresh and are they inserted correctly?
If you are using a wireless mouse, have you pushed the little "connect" button on the bottom?
You haven't said, but is the other mouse a wireless one or a USB mouse? If your USB mouse doesn't work, try another USB port. If you go into the device manager, do you see a "human interface device" or a "mouse" listed? If so, it will tell you the system recognizes the device. If that is missing, there is a good chance the mouse is dead.
Oct 31, 2011 | Computers & Internet
My SYLVANIA mouse model # SY-040R is not working. It worked for about a month and then stopped working. It is a usb retractable optical mouse. Please Help!
optical mice suffer issues like anything else, just because it has no moving parts, doesn't mean it's never going to quit.Try the obvious, move the mouse to another port on this machine or another machine, to confirm the malfunction, after this I would encourage you to take your newly confirmed mistake back to the retailer, as it is only 30 days old.
Jun 08, 2011 | Computers & Internet
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
Unsupported pixel shader version detected. 2.0
3 solutions:
(1) Change your graphics card.
(2) Download and install 3d analzye and check skip pixel shader 2.0 (check other settings if needed)
(3) Download Swiftshader and copy d3d8.dll and d3d9.dll inside the game directory and start the game.
(Beware using 3d analyze and Swiftshader will be very slow.So the wisest thing to do is changing your graphics card.)
Apr 27, 2011 | Capcom Devil May Cry 4
Activision Call of Duty 2 for Windows Logo
149 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
