Question about Maytag MSD2432G Side by Side Refrigerator
Buzzing noise I purchased a new msd2432grw in 2004. Recently, it has started making a buzzing noise that lasts for about 30 seconds. It can occur randomly--sometimes I don't hear it for hours, sometimes once right after another. It doesn't seem to have anything to do with the icemaker. I have turned it on and off and same sound. Thanks for any suggestions!!
  • rebecca5063 Aug 24, 2008
    Same problem this past week except constant every 2.2- 2.5 minutes. Then, after about 3 days of this, freezer stopped freezing completely- lost all food overnight. No solution here, but just wanted you to be aware of possible upcoming stoppage so that maybe u can save your contents.
    Dave
SOURCE:
SOURCE: Making Noise
I have the exact same problem. The faint buzz gets louder and more frequent over the course of about a week, and then stops cooling. I have been looking around and find that it is most likely the relay/overload and hopefully not the compressor. My problem started after having an AC unit plugged into the same circuit trip the breaker. I am going to replace the part myself because it looks really simple. I will post my results. I will hopefully getting the part tomorrow. My frige is not quite 3yrs old, and from the look of it, this looks like a common issue with this model. If it is the compressor it should be covered by the 5yr warranty.
Model #: MSD2732GRS
Serial#: 11839591EN
Relay/Overload Kit Part Code: 4SP04D419LF
Posted on May 31, 2008
  • 198 Answers
SOURCE: msd2432grw problem - freezer not frozen and clicking off sound
This sounds like a stuck compressor, you really should call a service tech. to verify that the compressor is faulty or maybe a bad start relay. A qualified service man can verify this problem. If it is in fact a bad compressor you will probably opt for a new refrigerator.
Posted on Jan 09, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Posted on May 28, 2009
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
  • 6 Answers
SOURCE: freezer not freezing food
try turning off the whole of the freezer off then clean it and clear all the food out then switch back on then put it on cold as normal then click super or too make the process faster button to make the freezer colder
Please vote if works thanks :)
Posted on Jul 22, 2009
SOURCE: my maytag refrigerator started making a buzzing
I have the same problem. It is ice buildup around the evaporator fan that begins as a buzzing (the fan blades hitting the advancing "glacier"), which ultimately stops the fan and then the freezer/fridge stop cooling. Just pull the lower sheet metal from the inside rear of the freezer (need to remove some screws from upper sheet also) and chip the ice away. I've got a question in to Maytag now to see how to prevent this from recurring. I've had to take the thing apart 3 times in 2 years.
Posted on Aug 27, 2009
The t.v. makes a buzzing noise while running and 30 seconds or so after shutting down.Is this a problem with the color wheel?if so what is a color wheel,what is the price of this part.How much should the...
First ascertain that televsiion least is functional making possible reacquirng an alternate
Second, requiring an alternate television altogether least requuires repairs or malfunctions at prior date
Circumpsectively, ascertain that the televison least is within restorabilitiy make way to purchase new devices.
Mar 02, 2011 | RCA HD50LPW165 50" Rear Projection HDTV
I am getting buzzing noise somewhere in the car even if the is off. I started getting this noise last year. It was never there before. It is a 2004 Range Rover
I had the same problem with my 04 RR, the issue was a faulty fan in the ECU. when the noise occurs open the hood and on the passenger side theres a "black box" listen to see if the noise is coming from there if it is then its the fan. was told this is common, cost me $250 to replace. hope this helps.
Sep 13, 2010 | 2004 Land Rover Range Rover
Hi Have recently purchased a Honer 280 /64
These harminicas are warranteed and rarely have problems. Either return it to the place of purchase for an exchange or contact Hohner directly. My experience with this company is that they are eager to make things right.
Dan
Aug 26, 2010 | Hohner Super Chromonica Chromatic...
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
1998 Lexus gs300 at idle Very loud buzzing type noise from engine
check brake fluid level.
master cylinder might be of interest, but i would check the fluid level first
Apr 08, 2010 | 1998 Lexus Gs 300
My drive is making a buzzing noise and not starting up
Even though you do not use it alot it sounds like it is failing i recomend a new drive
Dec 01, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Buzzing sound coming from TV
Sounds like a power supply, could be a large capacitor or a large transformer making the noise
Mar 14, 2007 | Harsper HP-4200VPM Television
Maytag MSD2432G Side by Side Refrigerator Logo
57 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
