Question about Western Digital WD2500BEVT-22ZCT0 - 250GB 5.4K RPM SATA 2.5"" Hard Disk Drive HDD"
(( harddisk security password )) i need a master password.thanks
After tree wrong code i see this message (( enter unlock password (key:52283521)
    Problem Solver:
  • 5 Answers
Reset the cmos by replacing the cmos chip to the other two pins on the motherboard (there r three pins) and remove and refit the battery and replace the cmos chip to its original pins, that will reset the bios password which is asked prior starting OS or format the harddisk partition using windows installation disc, hope that helps
Posted on May 10, 2013
I have a nokia 7210 supernova and by mistakly while playing i enterwd the wron security key word and when now i am entering the correct keyword its saying wrong password,what do i do??????????
To Unlock the Nokia from the Security Lock You can use the Master Reset Code.,You can get the Master reset code at Reliable cost at http://www.mobile-unlocker.com/unlocking-services/rs2wp6/ and Unlock it.You can check for Your model in the availability list.
Nov 07, 2010 | Nokia 7210
E500 compaq bios pasword removel
enter 3 time wrong password if u get a code send me that code ill send u master password thanks
Aug 30, 2010 | Compaq Armada E500 Notebook
My hdd lock pasward ,ask me to put user hdd pasward. and i forget it what can i do?
Unlocking a password protected harddisk During development of the Rockbox firmware, on several occations the harddisk has become locked, i.e. password protected. This results in the Archos displaying:
Part. Error
Pls Chck HD
We are still not 100% sure why it happened. Theories range from low-power conditions to accidental chip select failure. It has also happened for normal users, using the standard Archos-supplied firmware, although it was more frequent for us developers.
Note: None of us developers have experienced this problem since march 2002.
We do however know how to unlock the disk:
Windows/DOS unlock Note: This requires taking the Archos apart, which will void your warranty!
  1. Grab atapwd (written by Alex Mina)
  2. Create a bootable DOS floppy disk, and put atapwd.exe on it
  3. Remove the harddisk from your Archos and plug it into a laptop (or a standard PC, using a 3.5" => 2.5" IDE adapter)
  4. Boot from the floppy and run atapwd.exe
  5. Select the locked harddrive and press enter for the menu
  6. For Fujitsu disks: Choose "unlock with user password", then "disable with user password". The password is empty, so just press enter at the prompt.
  7. For Toshiba and Hitachi disks, if the above doesn't work: Choose "unlock with master password", then "disable with master password". The password is all spaces.
  8. Your disk is now unlocked. Shut down the computer and remove the disk.
Big thanks to Magnus Andersson for discovering the Fujitsu (lack of) user password!
There is also a program for win32, ArchosUnlock.exe, that creates a linux boot disk with the below mentioned patched isd200 driver.
Linux unlock For those of us using Linux, we have written an isd200 driver patch for unlocking the disk. This modified driver will automatically unlock the disk when you connect your Archos via USB, so you don't have to do anything special. Apply the patch to a 2.4.18 linux kernel tree.
Still locked? If the above suggestions don't work, here's some background info about the disk lock feature:
The disk lock is a built-in security feature in the disk. It is part of the ATA specification, and thus not specific to any brand or device.
A disk always has two passwords: A User password and a Master password. Most disks support a Master Password Revision Code, which can tell you if the Master password has been changed, or it it still the factory default. The revision code is word 92 in the IDENTIFY response. A value of 0xFFFE means the Master password is unchanged.
A disk can be locked in two modes: High security mode or Maximum security mode. Bit 8 in word 128 of the IDENTIFY response tell you which mode your disk is in: 0 = High, 1 = Maximum.
In High security mode, you can unlock the disk with either the user or master password, using the "SECURITY UNLOCK DEVICE" ATA command. There is an attempt limit, normally set to 5, after which you must power cycle or hard-reset the disk before you can attempt again.
In Maximum security mode, you cannot unlock the disk! The only way to get the disk back to a usable state is to issue the SECURITY ERASE PREPARE command, immediately followed by SECURITY ERASE UNIT. The SECURITY ERASE UNIT command requires the Master password and will completely erase all data on the disk. The operation is rather slow, expect half an hour or more for big disks. (Word 89 in the IDENTIFY response indicates how long the operation will take.)
May 03, 2010 | Toshiba Satellite A205-S5804 Notebook
Security code for N73
356406017443168
master code:
5335036136
356406014836323
master code:
7151635151
for the rest just post your IMEI number, for your master code
Apr 26, 2008 | Nokia N73 Cellular Phone
Security code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 23, 2008 | Nokia 3110 Cellular Phone
Security code Nokia 3110 classic
SIM pin code:
Master Reset Code
Apr 17, 2008 | Nokia 3110 Cellular Phone
Resetting Security Code
SIM pin code:
Master Reset Code
Apr 13, 2008 | Nokia 3110 Cellular Phone
Pass word
Master Reset Code
"Forget the Joneses. I can't keep up with the Simpsons!"
Apr 12, 2008 | Samsung SGH-D900 Cellular Phone
Unlock Nokia N95 8GB
plz give nokia n95 master cod
Apr 05, 2008 | Nokia N95 Cellular Phone
Lock code
SIM Pin Code.
if your sim is put into another handset. ---
To reset this Pin number you need the:
If you miss keyed (or forget) your SIM PIN code, and enter the wrong one 3-5 times in a row, the sim will lock up, and you'll need to enter the unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don't try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a "new" sim if the phone security code is entered.
To reset this Security number you need the:
Master Reset Code
For IMEI 356404010441953 this is the Master Code:
3520316615 to use it:
You type in the security codes (any) until the phone request the Master code; when it does, leave your phone still, don't use it for 15 minutes, then type in the Master code.
Mar 25, 2008 | Nokia N73 Cellular Phone
Western Digital WD2500BEVT-22ZCT0 - 250GB 5.4K RPM SATA 2.5"" Hard Disk Drive HDD" Logo
233 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
