Question about Vehicle Parts & Accessories
F350 door locks
My door lock on a 2004 f350 won't work.
    New Friend:
I'm not sure but there should be a fuse that's in the circuit. Because I doubt everyone of the door lock actuators aren't working. They are usually located at bottom of door toward rear of door with big rivet holding them in. I'd check owners manual for fuse or relays locations & check those first. Hope this helps at least the tips anyway
Posted on May 09, 2013
  • zach_foster May 09, 2013
    Sweet thanks ill try and find it. Thank you
Auto door lock don't work, they click when activated. Also the door ajar light stays on and auto light does not work. F350 super duty 2002 ford
You might need to oil the locks. Our truck does that some times. We just spray some WD40 on the catches and keep clicking them back and forth till it sinks it. As for the ajar light, the sensor inside of the door jam might be damaged. or the switch on the lights is turned on. I did that once.
Feb 27, 2013 | Cars & Trucks
My 04 f350 speedometer&doorlocks stopped working any help please
The system is controlled by a centralized module, you must have that tested as the first step.
Aug 05, 2012 | 2004 Ford F350
2002 Ford F350, Door Ajar Light on constantly, Auto Locks don't operate, Auto Headlights don't operate(only manually), Dome Light does not operate when opening doors, Remote does not work. All
Your keyless entry system is going bad and you need a battery for your keyless entry system once you replace your battery with the new one thing should work properly
Feb 06, 2018 | Ford Cars & Trucks
2001 ford f350 power door locks not working
Check fuses first, then switches on both doors, if nothing still you will have to pull the door panels and inspect the master lock switch (drivers door) and see if anything is loose or corroded.
Nov 07, 2011 | 2001 Ford F350 Super Duty SuperCab
2004 f350 4x4 auto hub doesn't wont to lock in
a lot of those are ran by vaccum actuator that engauges the frontend for four wheel drive, most of the time is is on the back of the front punkin, you cant miss it, it will have a wire pluged into it as well as vaccum hoses... hope this helps
Jun 28, 2011 | 2004 Ford F350
My 2004 f350 4x4 will not go in to 4wheel drive when the hub are in the auto position if i lock them it works. Looking for a repair manual Brad
vacumed line pull the hub lock in auto
check the line at selenoid (right side fender under hood)
for voltaged when in auto and for vacumed then follow line to hubs
check for cut or pinch or rubbed or burned
disconect at hub and test there for vacumed if yes
pull hubs off clean and inspect o-rings
Dec 17, 2010 | 2004 Ford F350
Electric door locks don't work from remote
You may have a bad remote or it needs to be reprogramed.
Jul 15, 2009 | 1995 Ford F350
Trying to replace broken driver side door handle on '04 F350
remove interior door panel un hook lock and latch arms then there should only be a couple of cir clips holding the handle in
Jan 09, 2009 | 2004 Ford F350
2004 F350 Powerstroke won't go into 4 wheel drive
do you have automatic hubs, or do you have to lock them manuelly?
Nov 24, 2008 | 2004 Ford F350
How to replace actuator on F350 V0
My right sliding door's lock doesn't function either. I took off the door panel and found that the lock mechanism was broken. Normally I would think this strange, as the lock mech is metal. But since this is a Plymouth product, I some how think it should be normal for something to break off without it ever getting a direct hit. I can only assume that my kids closing the door too hard might have had something to do with this. Anyway, the whole lock mech needs to be replaced, and I haven't even tried to see how much that will cost me. This Van has cost twice in repairs than what I paid new for it. (just kidding, but it sure feels like it). If you have an answer to this query
Jul 03, 2008 | 2003 Ford F350 Super Duty DRW SuperCab
Vehicle Parts & Accessories Logo
114 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
