Question about Garden
Lawn mowers I bought a Troy Built push mower from Lowes two years ago and it fired up on the first pull yesterday and just before I finished mowing the grass it started running like it had no power then it stalled. WQhen I pulled the cord it fires up and then stalls? I ran all the gas out of it last season so my gas is fresh. Sounds like an electric problem?
    New Friend:
Maybe it need a spark plug
Posted on Feb 01, 2014
SOURCE:
Troy bilt lawn mower
This is not a common problem. The bolts are at fault. You can replace them and it will work but make sure they are the right bolts and you put them in tight.
Jul 13, 2013 | Garden
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Troy bilt self propelled assembled in the box got it out of the box and finished setup but when it came to the pull start cord it would not pull am i missing something?
The unit has a safety feature that stops the engine with a brake when you release the handle. In order to start the engine you have to release this brake by squeezing the handle lever as if you were mowing. You have to hold this lever in that position as you pull the cord.
Aug 02, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Rope on mower won't pull.
due to the ethanol and additives in todays fuel it can also be your carborator. one of the intakes may be clogged and all gummed up.
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Troy built lawn mower does not go on
you need to be sure the battery you are jumping is fully charged to start with.
Apr 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
91 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
