Question about Gem Sound GemSound GM-15 Consumer Microphone
Manual how to raise volume on receiver
How to unmute the reciever
raise the volume or select mute , if its not working on the remote , turn off the AVR ( receiver ) manually and raise the volume up manually that way.. i know it sounds simple , it should be... good luck The Cable Guy
Mar 04, 2015 | Sony BRAVIA DAV-HDX285 5.1-Channel Theater...
I have a Sharp LE820 TV and all of a sudden the volume level raises by itself, what can I do to solve this problem?
1st thing to do is remove the batteries from the remote and see if it still changes by itself, if it does then I'd look at main board issues
Mar 06, 2018 | Sharp AQUOS 52in. LE820 LED LCD HDTV
Hello I can hardly hear on all of my channels. I have directv and I can't get a reasonable volume. Is there something I can do to fix this problem?
Directv low volume problem.
One sure way to eliminate Directv's low volume and any other volume problems in general is by installing a stereo compressor between your Directv receivers audio outputs and your TV's audio inputs. (Simply plug the compressor's outputs into TV and your receiver outputs into the compressor's inputs). By correctly setting the controls on the compressor, you won't loose the dynamic program content. Not only will it raise the volume level to where you want it be, it will also prevent it from exceeding any set level you chose, actually limiting how loud any sound can be. These settings are fully adjustable. In other words when you switch from Directv back to a dvd or any source, no more sound blasting, you can set levels to be the same now since you have raised then adjusted Directv's level to normal. Plus a compressor will raise those low hard to hear audio sections often found in movies. This is the reason we used them all the time in the recording industry. Another benefit is it levels all channels on Directv. The result, channels are now the same volume. This is what I'm doing to end the problem. Hope this helps someone. J Pynckel
Jul 27, 2010 | Directv H21 DTV Receiver
Yamaha rx-v530 volume maxes out when turned on
If you are using the remote to raise the volume of the unit, my advice is to forget that function, and turn volume manually. I had a similar problem with a Sony receiver and the solution was simply to put aside the remote. Remotes are infra-red based, and if you have other components with infra-red this can cause undesired interference and malfunction. Good Luck.
Flavio/BRAZIL
Jul 26, 2010 | Yamaha RX-V530 Receiver
Increase default volume setting on Toshiba DKT3220-SD?
Depending on what system you have it can be programmed in system programming. This must be done from Ext 205 and your manual can be found here.
http://guides.idacomusa.com/
Jun 04, 2009 | Toshiba DKT3020SD Corded Phone
Receiver shuts off when volume raised above 10
A fuse breaker or resetting electronic componet device attaced to the audio receiver protects the amp & speakers for destruction! The quality of the amp ,spkers& spks. wires help on choosing for protection shut downs! Of course at 10 volume you risk all of the amp in the receiver , buy a higher quality brand reciever ,intergrated amp, single amp . BE CAREFUL AT THE HIGHER VOLUME RATINGS YOU RISK HEARING DAMAGE! FOR REAL!
Feb 04, 2009 | Philips FR975 Receiver
Raised volume cuts sound and gives me "overload" message
A couple of possibilities: Bad solder on power regulators (attached to main heat sink) or cooling fan may not be turning on when volume is raised.
Jan 16, 2009 | Audio Players & Recorders
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Gem Sound GemSound GM-15 Consumer Microphone Logo
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
brian williams
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
