Question about Hardware & Accessories
What shows on or off? With the line showing or without?
  • Raine Guy May 09, 2013
    It is a Yardworks Model 59-7470-0
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model device?
Posted on May 08, 2013
Show fuel line routing on weed eater by troy built.
Many Parts manuals don't show the actual fuel line routing.. The pipes have to go from the tank to the carb or primer bulb, generally a direct route without being trapped or rubbing. If you're referring to what pipes go to which part, then that's another question I could answer if asked. Thank you
May 15, 2016 | Troy Garden
How to get incoming calls to two handsets
The system should be configured so that the desired lines, whether CO or extensions, are set to "Appear and Ring" on each set.
Config... Terminals&sets... Show Set... (enter #)... Find...Line Access... Line Assignments... Show Line (enter #)... set to "Appear and Ring" on each set that needs to ring.
You can also have a line "Ring Only" without an appearance (dedicated button), in which case it will show as an intercom call.
Sep 25, 2014 | NorStar T7316E Telephone
My Iphone will not or vibrate, a bell shows with a line across the front then shows without line
You've got the phone on silent. Check that the switch on the side of the phone is not toward the back of the phone, but towards the face
Jul 15, 2014 | Apple iPhone Smartphone
How can I get the dial tone turned back on without lifting receiver? I want to be able to lift the phone and answer without pushing Line 1
To answer a ringing line by just lifting the handset that phone has to be programmed to ring on that line. This is done in the programming mode under 'terminals&sets/show set__/Line Access/Line assignment/Show line:__/...then your choices are: Appear and ring,Appear only, or Unassigned. Choose appear and ring on each line you want to answer from that telephone. Hope this helps.
Bill C. www.dyna-tech.com We also do remote programming and tech support on Norstar CICS and MICS.
Apr 09, 2010 | NorStar M7310 Corded Phone
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
Oct 19, 2009 | NorStar Meridian M7310 Phone
Thin vertical line on screen shows what another part of screen is
Ah, the "line of death."
There sure is & best of all, it's FREE. You will need a piece of tin foil rolled up to a pencil's thickness. You will also need some patience to watch THIS video, which shows you the placement for the tin foil. As pointed out in the video, you only need to remove the face plate & NOT all of the buttons, D-pad.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Slim...
Error
Since the 2nd Button works press [2nd] [MEM] [7:reset] [F1][All ram] [ENTER]. That may help
Jan 13, 2009 | Texas Instruments TI-89 Calculator
Run dos command through vb 6.0 without showing it
visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
Mar 20, 2008 | Computers & Internet
Hardware & Accessories Logo
14 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
