Question about Samsung Televison & Video
Pn58b650s1f clicks when turn on but dead other than clicking
Why doesn't it crank?
Take it to ASE certified repair shop ,they will help you >
Mar 31, 2016 | Chevrolet HHR Cars & Trucks
When I turn key I get click but will not start
I single click typically indicates a bad starter solenoid and a new starter will generally fix the problem.
I series of rapid clicks when the key is held in the crank positon usually indicates a weak or dead battery. a new battery will usually solve this issue.
A bad connection at the battery can also cause a single click but typically the whole car will go dead for a brief period and then everything will again turn on. Cleaning the battery terminals will typically resolve this issue.
Nov 16, 2015 | Cars & Trucks
The battery goes dead won't even jump and turn
the clicking sound is the starter relay check battery starter motor and this clicking relay hope this helps ivan
Oct 15, 2012 | Cars & Trucks
BATTERY WONT TURN OVER MAKING A CLICKING SOUND
A single click when you turn the key to the crank position usually indicates a bad starter. A rapid clicking noise usually indicates a dead battery. If you hear a click and everything goes dead there is a bad connection at the battery.
Dec 28, 2011 | 1999 Toyota RAV4
When you turn the key over it is not starting, it
If its just one click each time you hit the key, may be starter. I would check to make sure the battery is not dead or bad. If it is a bunch of clicks at once, its probably a dead battery. But why is it dead? Possible- Old battery, left lights or power on, maybe didnt close door all the way, or alternator going bad and not charging battery. Try to jump it or charge/replace battery.
Jun 26, 2010 | 2002 Ford Explorer
When you turn the key you hear a click, click click and then nothing
The click, click, click you are hearing when you turn your key is the starter solinoid attempting to engauge but because the battery is dead it will not engauge. Charge the battery then start the car and check the voltage to the battery. It should be between 13.5 vdc and 14.5 vdc. If it is not, the alternator is bad. If the voltage is between the above mentioned values and the battery goes dead again it is a bad battery.
Nov 16, 2009 | 2001 Hyundai Sonata
2006 ford explorer won't start, just clicking sound
Problly bad connection to the battery check cables if so try to clean battery post.
Mar 21, 2009 | 2006 Ford Explorer
1999 Isuzu Rodeo Won't Start
does it click multiple time or just once
many click click click click means you have a dead battery
one click means you have a starter circuit issue good luck
Jan 27, 2009 | 1999 Isuzu Rodeo
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
