Question about Pool & Spa
Hayward pool pumps
How do remove the impeller on a Hayward power flow matrix pool pump
  • 717 Answers
The impeller on this Hayward pump unthreads counter clockwise.
Take a big flat head screw driver and put it on the center shaft on the back of the motor to hold the shaft solid while you unthread the impeller.
Rod
US Parts Center
Posted on May 09, 2013
john224
  • 1378 Answers
SOURCE: Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Posted on Jun 14, 2009
protek480
  • 1714 Answers
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
Posted on Jul 03, 2009
  • 156 Answers
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Posted on Jul 06, 2009
  • 136 Answers
SOURCE: I have a hayward 2hp pool pump motor that hums but
your starter capastor has gone bad or got diconnected it`s look`s like round cylender 2 inch by 4 inch dimention`s or it could be an internal (inside the motor) depending how new the motor is
Posted on Nov 06, 2009
Testimonial: "Thank you very much for your help"
MOTORWIZJ
  • 1368 Answers
SOURCE: I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
Posted on Apr 07, 2010
THe skimmer is not pulling much water in from the pool
if you have ever run the pump without the strainer baskets, this might be the problem. it doesnt take much debris to block the impellers and reduce the water flow. if this is the case, you will have to split the pump and use a shop vac to remove all the debris from the impeller
May 30, 2014 | HAYWARD IMPELLER RING
Pump runs but humms
Question:
What do I do if my pool/spa pump is humming and has low flow?
Answer: by Osko Pool n Spa Pool/Spa Pump Humming and No Flow If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
1) Remove the pump motor from the system.
2) Disassemble the front half of the Pump Pot Housing from the back half.
3) Check for any foreign obstructions which would jam the Impeller and remove it
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged and requires replacement.
5) Next, remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
If everything seems to be in good working order, then you need a new pump... not just replacement parts.
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 15, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
Can I upgrade from Hayward 2hp ao smith pool pump to 2.5hp
Yes you could upgrade the motor from a 2.0 to a 2.5 but this will not result in an increase of your water/pressure flow?
This would slightly reduce the load on the motor as the impeller inside the pump is specifically matched to the your motors amperage.
Oct 29, 2012 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
MY PRESSURE IS ONLY A 5 AND IS USUALLY 18-20 WHAT COULD BE THE PROBLEM. WE BACKFLUSED AND DID WHAT THE BOOK SAID BUT DID NOT WORK
Check your impeller. Remove the pump motor from the housing to inspect the impeller. Be prepared to replace the seal.
Let me know what you find.
Thanks for using FixYa.com
Jul 25, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
We have an older model Hayward Power Pro LX pump. The pump is running but no water is pumping through. Can't find a tech drawing.
well of course you need to make sure the filters are not blocked up, Skimmer basket etc......I have seen on few occasions the impeller shaft has broken, so the pump runs like it doesn't have a trouble in the world.....but the impeller isn't turning, therefore no water flow.
Sep 03, 2010 | Hayward Pool Products Hayward Power Flo LX...
Powerflo matrix pump is humming not pumping
I think you have a start/run capacitor issue or your impeller has spun its center out. Check the impeller first. If the impeller is intact, take your motor to your full service pool professional for repair.
Aug 01, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Hayward pump hums only
Replace your start capacitor ... before you do that ... is the hummng the motor withoug the impeller? Your impeller may be broken.
Jun 25, 2010 | Hayward Pool Products Hayward Power Flo LX...
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
How do i remove the impeller from a self priming max-flow pump by hayward
Lock the shaft at the back of the motor and spin the impeller off counter-clockwise.
Oct 02, 2009 | Hayward Sp2805x7 Max-Flo 3/4 Hp Swimming...
Pool & Spa Logo
43 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
