Question about Toys
Jcb plt25f assemble diagram for line head
Line assembly wont turn
Drive shaft sheared?
Jun 02, 2015 | Garden
Jcb plt25 fuel tank parts
At a store that sells garden machines. Take the line you need with you as there are various size fuel lines.
Aug 17, 2014 | Garden
Hi has anybody got an wiring diagram for a 1985 jcb 814 as kids have tore out all the wiring and ignition switch
Man, you have a problem!! Try ebay or a used machine breakers yard for a used harness. There are dvd's available for the JCB range covering parts but you may get one for wiring. Try the JCB owners forums for help
Aug 15, 2014 | Electrical Supplies
Jcb jz70 lacks power
Sounds to me like you have a hydraulic lever or pedal open and its dead heading against a closed port. Possibly to an attachment line. I'm not sure about the JCB on this, but if you can put other attachments on the unit, there has got to be an actuating lever or pedal to open the attachment lines for actuation.
Jun 20, 2014 | Vehicle Parts & Accessories
Ineed a shop manual for jcb Mini Excavator serial no SLP08037E0828473
you can go to this site and download it right away JCB
Feb 14, 2013 | Garden
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Wiring diagram JCB 4CX
what typ of oil use on jcb 4cx transmission?
Nov 05, 2011 | Bruder Jcb 4CX Loader
How do you remove the complete string head from the shaft of a weedeater model 316 795001
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-316795001/0247/1503820/P0090470/00002
The parts diagram above shows part #25, that part located just behind the head should have a small hole in the side about 1/4" diameter. That hole lines up with another hole inside to stop the shaft from turning . You need to line up both holes visually then insert a small phillips screwdriver in through both holes, that will hold the shaft still while you turn the whole head assembly with your hand. When removing the head assembly it should turn counter clock wise,when looking at it from an operating position, meaning that the threads are left handed.
Jul 12, 2011 | Garden
JCB 3CX Back Hoe Overrun
Depending on the year (what cab colour  or dash modeal?) its the slew ram seals or cross line relief valves for the same .
Oct 25, 2009 | Garden
Toys Logo
16 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
