Question about Apple Computers & Internet
Line on monitor
Red line running vertically on my monitor? Will not go away and have no idea how it got there.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Here's a video VISHAL NAYAK suggested as a solution to your problem from YouTube:
How to Fix Vertical Lines Laptop Screen FOR FREE/EASY
Posted on May 08, 2013
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 30 Answers
It might be either lcd or video card problem. More chance are it's the video problem. You can try to reset PRAM by the way.
Tech from http://www.computerstar.ca/Macbook_repair_mississauga.html
Posted on Jun 02, 2013
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
What is the cause and is there a fix for the two vertical lines in the center of my LG monitor.
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 11, 2014 | LG M4225CCBA 42 LCD TV
Red line on monitor
It's is either a screen or video card issue. Only an apple tech can repair or replace parts as needed.
May 08, 2013 | Apple Computers & Internet
Laptop Screen Shows vertical Red lines on Grey Color on random Spots
Check the cables. It might be overly simplistic, but if your monitor is connected via a serial cable, one of the pins might be bent or missing. This can cause slight display problems, including a vertical line. If you are using a USB, try another cable and see if the problem persists. Update your video card driver. Some discrete cards have an update feature in the properties window for the device. Right-click on your video card in the programs list, and select "Properties." The update will be a button under the "Drivers" tab if your device is so equipped. If not, visit the manufacturer's website and search for the most current driver for your model number.
Updated video drivers could solve the problem. Place a box fan directly behind your computers intake vent for extra cooling. Sometimes if there are system problems, your components can run too hot. If cooling the computer takes away the line, you know have you an overheating problem, not a monitor problem. You might try cleaning the internals with canned air. Remove the housing, and thoroughly blow any dust, hair or carpet fiber away from the fan and off the mother board. While you're there, you can check to see if there are any obvious loose connections. Connect the monitor to another computer if you have one available. This is probably the most definitive test of your monitor's health. If you have a line when the monitor is connected to a different machine, it's likely time for a new monitor. As frustrating as it sounds, taking apart one of today's monitors in an attempt to repair it is more expensive than buying a replacement. If you don't have another computer available, try shutting down the computer but leave the power on to the monitor. Using the buttons on the monitor bezel (if you have them), call up the settings. If the line appears in the menu just as it did in the video from your computer, then you definitely have a monitor problem. Replacement is probably in order
Dec 10, 2012 | Computers & Internet
Vertical lines on screen , is there a processor driver download to fix this problem
Vertical lines on a screen is not a processor problem, vertical lines is going to be a problem with the monitor or the video card. Try a different known working monitor on your computer and if the lines go away then you know that the original monitor is bad.
If the lines don't go away then try replacing the video card. If you have integrated video then the motherboard would need to be replaced. A processor driver download is not going to fix a vertical line problem.
Aug 08, 2009 | Dell Computers & Internet
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Thin red vertical line length of screen(right side)
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 20, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
A single vertical red line
That means the LCD panel itself (the actual glass) is broken. Don't delay, return it and get another before it's too late! The problem will most likely NOT go away, and there is no fix other than to replace the panel itself. The panel, when purchased separately, can cost more than the monitor itself.
Dec 27, 2007 | LG L1915S 19" LCD Monitor
Computers & Internet Logo
98 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
