32v smps circuit - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
Posted on May 09, 2013
I need a contactor or relay with a 32 v coil and can handle minimum 40 amp
many shops and stores provide this.. if you talk to a local elecrician i am sure he is able to obtain it for you, or you can do a simple google search witch will give you many alternatives. following are a few i found by a quick search
Solid State Relay 40A 3 32V DC Input
60A AGT SSR Solid State Relay 3 32V DC 24 380V AC 24V 380VDC Newegg com
Aliexpress com Buy 1pcs SSR 100DA 100A Solid State Relay Module 3 32V DC...
if none of these fit your requirement. there are cheap and easy ways to drop the voltage across the coil. so you may use a 24v version if you do
Apr 10, 2017 | Dehumidifiers
Why my hp designjet 500 smps has high voltage than normal
check power supply and if voltage are good change Electronic module its damaged. this voltage what you are write not normal!
May 21, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
Insignia ns ltdvd26 09
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Aug 27, 2017 | Televison & Video
Power Supply Output
No as long as the output voltage is the same and the supply amps is greater than 375mA.
Dec 20, 2012 | Office Equipment & Supplies
My camper fridge , Engel SRBT-565D Does not run on 12V ?
The compressor is on the way out and exceeds the current capacity of the 12v inverter circuit. The compressor runs on 32V AC @50 Hz and the inverter circuit is not able to produce sufficient current when the compressor becomes worn. It still runs on 240V circuit as this is a straight step down transformer from 240 volts and is not current limited..
May 20, 2012 | Freezers
My tv tries to turn on but shuts right back off
SMPS circuit problem Check the SMPS . Replace opto couplers.
Do not switch ON TV without opto coupler in circuit. SMPS will go out of control and the + DC voltage will raise and spoil the circuits.
Sep 04, 2010 | Sanyo DS27930 27" TV
No power coming on intel desktop motherboard d845
Check the power supply to the motherboard i.e the SMPS, if it is working the fan of the SMPS will rotate. If the SMPS is ATX you can check it without connecting it to the motherboard. Unplug all the SMPS power connectors from the motherboard and then short circuit the green and the black wire of the 20pin connector of the smps, if the SMPS is working the fan of the SMPS will rotate. If the SMPS is in good condition and working, than it might be a problem in the internal circuit of the motherboard.
Check the process here:-
http://www.jestineyong.com/?p=267
Jul 19, 2010 | Intel D845GVSR Motherboard
ATX-300GU PSU: 32V around Q4/Q5 circuit
could just be the regulating power transistors are burned out or one of their biosing components, there a few meaty capacitors that may be causing a surge, but the safe thing to do would be to start with a new one, the reason is, modern drives are so sensitive that you could blow their circuitry and then lose the harddisk! All the best - the Yeti
May 17, 2009 | AOpen Power Supply: ATX-300GU (PS4300GU)...
How do you get to the spark plugs on the 99 lincolin 32v
I have the same question as baldie (posted 5/17/09), as how to access the spark plugs on a 32V V8 in a 1999 Continental. No one has posted a response.
May 17, 2009 | 1999 Lincoln Continental
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
