Question about Shoprider Shop Rider Gk83 Dasher 3 Scooter Shprgk83
Wheels wont turn when any weight is put on them?
When scooter is turned on wheels move but when any weight is put on them they wont turn?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 215 Answers
TURN UP IDLE SPEED
Posted on Jul 03, 2013
2 Suggested Answers
SOURCE: put in new batteries and scooter will not do anything
It could that your potentiomenter is broken and would need to be replaced. simply removed the housings from both sides to get to the throttle part and check to see if the spring is not broken. if it is broken, simply remove old one and buy new one which should be around 60.00 and up in cost. can go to this website to check
http://www.monsterscooterparts.com/mobility-scooter-throttle-pot.html
Posted on May 24, 2012
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
I charged scooter and it still won't move back wheels seem to be locked up
that's normal the wheels r locked if u moved the free wheel lever check to c if its back in lock position if it is and the scooter wont move it might b an electrical problem check to c if its got a reset button ....good luck
Jul 02, 2015 | Health & Beauty
Stopped going when free wheel lever accidently pushed forward. Put back. Still wont start.
Check for error codes. Move free wheel lever in and out a few times in case the brake micro switch is not making correctly.
Check speed control is not turned down low.
Mar 21, 2015 | Pride Celebrity X 3 Wheel Scooter
I cannot start my Celebrity X mobility scooter. Drops into free wheel when I apply power lever.
After a fault has accorded with the scooter and you have reset the fault. Turn off the scooter with the key and count to 10 then switch on again. This will reset the fault in the system. If still have fault, try moving the lever in and out a few times in case the brake micro switch does not make circuit properly.
Mar 21, 2015 | Health & Beauty
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Rubbing noise rear end but not all the time
Hi.Most scooters use a steel key in each rear hub to drive the wheels. These often get noisy. As the wheel turns the weight is put on the key and then comes of as the wheel keeps turning making a noise each revolution of the wheel. To repair remove the rear wheels and wipe a thin smear of grease onto the axle and key. This will reduce the noise. Hint, loosen the bolts holding the wheel on before raising the rear end to remove the wheels. If you place a support or block of timber under the machine, be careful of the motor brush holders.
Other noises could be gearbox gears worn.
Good luck. Neil.
May 20, 2010 | Invacare Supply Group Invacare Lynx Large...
Scooter wont work. Charger shows "Green"......its been sitting for months. Just found the charger. When throttle is rolled on it makes a high pithched tone but crank wont turn the wheel...
Hi. I have had a few cases where the machine has been sitting in a damp room and the brake has rusted to the body and wont release. A few light taps with a small screw driver has usually fixed this. You will need to put the machine into free-wheel before doing this.
Could also be a faulty brake unit, that has seized up.
Try pushing the machine in free-wheel mode to see if the motor and drive wiil move.
Normally if there is an electrical fault with the brake assembly, then the machine will have a fault code on the display. good luck. Neil.
May 10, 2010 | RTO 12v 70ah Leoch Battery For Scooter Or...
2005 Pontiac G6 wont turn ignition cylinder with key. Tried to move shifter back and forth , pressed brake pedels , emergency brake. Still nothing. I am thinking its a locksmith issue. Any ideas? Thanks.
Try turning the steering wheel from side to side as you turn the key.I know there isnt really any wiggle room in the steering now,but you don't need to actually move the wheel very far, you are just putting enough weight on the wheel to take the load off of the steering wheel locking mechanism which is in a bind right now.
Feb 01, 2010 | 2005 Pontiac G6
Pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
Nov 02, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Shoprider Shop Rider Gk83 Dasher 3 Scooter Shprgk83 Logo
78 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
