Pioneer troubleshooting pioneer tx-1060L,seems frozen,display lit,buttons in-opretive
Onkyo TX-SR 805 flashes message "Test - < - 42" when switched on at power button.
Hello, you seem to be in technician test mode. Unplug the receiver for an hour, turn on and perform a reset by holding vcr/dvr and then on/standby. This should resolve your issue. Thank you, Onkyo USA
Mar 01, 2017 | Onkyo Televison & Video
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
User manual pioneer tx 608
A TX-608 is an old school tuner with one knob and two switches. You hook up some antennas and RCA cables and manually tune it. The manual, if available, would be more like a pamphlet.
Try web searching "pioneer tx 608 manual". Lots of service manuals out there.
Features:
http://stereonomono.blogspot.com/2010/11/pioneer-tx-608-1979.html
Aug 09, 2011 | Pioneer Audio Players & Recorders
I AM GETTING VERY LITTLE SOUND FROM THE SYSTEM
When did this start? What happened just prior to that?
Turn the volume DOWN for any further analysis. If it isn't loud enough to hear well at 1/4 volume, cranking it to the stops will not resolve it AND when you finally find the misplaced switch you may launch all of your speaker drivers right out of their cabinets.
Do you mean the MUTE button does not CHANGE the volume? It sounds like you're muted already and it doesn't UNmute. Is MUTING lit on the display?
Does it happen with all sources? Use onboard FM to troubleshoot as it can't be connected wrong.
Apr 01, 2009 | Onkyo TX-DS575 Receiver
CD Stuck in cd player
There should be a reset button on either the face of the player or under the faceplate if its removable (tiny black button). Otherwise to remove the cd disconnect the unit and then plug it in or remove the memory fuse or battery lead for 5 seconds.
Jul 05, 2008 | Pioneer DEH-P4100
The display isnt working
It sounds like the flexible pcb has snapped and will need to be replaced
Dec 24, 2007 | Pioneer DEH-P680MP CD Player
 Grubhead
Grubhead
