Question about Shoprider Health & Beauty
Have a shoprider scooter got a clutch,our problem is "wheels turn when turned on but if any presure is put on them while the motor is still running they wont turn
  • 11 Answers
SOURCE: User manual for shoprider madrid mobility scooter
Go to the Shoprider website and look for the scooter. It might have a different model name than the one you own. Get the name and click on the user manuals for the model that resembles yours (PDF file) and print.
Posted on Apr 02, 2009
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
  • 103 Answers
SOURCE: HAVE PUT SCOOTER TOGETHER AND CHARGED BUT IT
Make sure the scooter is not in freewheel.
Posted on Jul 23, 2009
  • 945 Answers
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Posted on Nov 06, 2009
  • 313 Answers
SOURCE: i have a 4 wheeled shoprider sunrunner scooter.
Possible one or both batteries have had there day. How old are the batteries. If they are between 1 and 2 years old they will probably need replacing. it would be adviseable to get the batteries tested and have the charger checked as well. When did it have its last service ?
Posted on Aug 01, 2010
I have a shoprider steamer. It wants to turn right when I push the stick forward or backwards. When it does go forward, there is a kind of jerking to it. If goes left fine. On and off problem.
The free wheel levers have got to be in drive mode. if one is in drive and the other side is not then the chair will try to go in circles. So if the right side free wheel lever is not in drive position then the chair will try to drive to the right because the right motor is not turning the wheel. The wiring to the right motor may have become disconnected.
Oct 10, 2016 | Shoprider Health & Beauty
Shoprider sprinter deluxe do I need to put grease in gearbox where surts are ? front motor runs slow and hot. back motor is good
Hi again I checked shoprider site on you're model and there is no mention of a front motor it only gives a listing on a 2 HP motor plus I checked monster scooter parts only one motor in there parts listing.,.???? Have u got the correct model. u don't have to put any oil in the transaxle unless u have dismantled it ...not sure what u mean by front motor .???? Cheers
Aug 01, 2016 | Shoprider Sprinter XL 4 Deluxe
Don't have a troubleshooting book. Replaced battery charger and checked all operations. Scooter beeps even with the brake in the run position?
Hi. Some shoprider machines have fault codes and most dont. I will try and cover what the main faults might be.
Free-wheel lever in the wrong position. Faulty brake coil. Resistance should be about 50 ohm's.
Stuck brush in the motor stopping the motor from operating. Check the resistance through the motor, should be approx. 1 ohm.
Speed lever ( wig wag ) not in central or neutral position or faulty..
Battery voltage too low or battery leads faulty.
Good luck. Neil.
May 15, 2010 | Shoprider Sprinter XL4
The voltage gage flickers the scooter beeps when i push lever to go forward i get a click near the motor .motor does not turn
hi, sounds liek a bad connection to the brake,
Check the connections from the brake (on the side of the motor)
back to the main connection , where the rear comes apart from the main frame check that connection, if you're are sure the connections are good, the brake may have failed, it not releasing the motor hence the beep.
Regards
GeWiz.
Jan 11, 2010 | Shoprider Echo 3 Wheel Scooter
My shoprider dasher just beeps
we just bought a shoprider monaco,after i cleaned it it did same thing just kept beeping,i found moving the free wheeling lever under back bumper a few times cleared it.Lever makes contact with a micro switch,on motor.
Hope this helps
Sep 09, 2009 | Shoprider Dasher 9 3 Wheel Scooter...
Schwin scooter not running properly
If the battery is old its likely that it needs to be replaced. Also, if batteries sit in the cold in the winter or are exposed to high heat they can be damaged. Try checking out http://www.batteryinternational.com/electric-scooter-batteries.html for a scooter replacement battery.
Jun 09, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Not running - full battery
hi look up www.americanmobilityscooters.com in Jacksonville FI 32211 ...Cheers
Apr 05, 2017 | Echo 3 TE SL7 3 New Electric Scooter by...
Health & Beauty Logo
19 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
