Question about Gigabyte Computers & Internet
Not powering on
Smps is working
  • 5,660 Answers
Deepati I would like to refer you to a previous solution of mine,
http://www.fixya.com/support/t18117565-medion_pc_mt_5_type_medmt79
Regards,
joecoolvette
Posted on May 13, 2013
Dell ps5022 2df how to test
remove smps and attach power chord to smps and sort green and black colored wire if fan works den smps is all rite if not den its faulty if smps is working den problem is with ur mother board
Jul 31, 2014 | Dell Computers & Internet
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
How to test this old dell smps,
hi,
take jump clip / a metal wire. Take the SMPS 20/24 pin connector. connect one end of the wire to black and other end to green. power the SMPS. If it is working its ok. otherwise SMPS having problem
thanks & regards
Anas K A
Jul 04, 2011 | Dell Power Supply for SMP-2450 (330 W,...
Ive had this bluray player for 2 years and it was working fine, then one day i tried to turn it on and nothing happened. i checked if the fuse was blown but i appears to be fine. so there is no power...
hi,
there is possibility of two complaints.
1, The SMPS power supply fault
2. the mother board fault.
if the SMPS is faulty the you can rectify the problem. If it is with the mother board the you have to contact the manufacturer .
First of all you have to check the SMPS ( switch mode power supply). you have to check the voltages at it secondary stage. 5v, 12v, etc
switched-mode power supply (switching-mode power supply, SMPS, or simply switcher) is an electronic power supply that incorporates a switching regulator in order to be highly efficient in the conversion of electrical power. Like other types of power supplies, an SMPS transfers power from a source like the electrical power grid to a load (e.g., a personal computer) while converting voltage and current characteristics. An SMPS is usually employed to efficiently provide a regulated output voltage, typically at a level different from the input voltage
for checkin the SMPS voltaes you need a multimeter. And check the voltages at it secondary stage
Added the inside view of BD 1600
if there is no outputs from the smps then you have to replace the SMPS drive STR ic near the big capacitor. Also ty to replace the OPTO coupler ic. y have to check the all resistors near the ic.
Remember one important thing that the capacitor can hold charge for some time even if you disconnect the power. so after removing the power. remove the SMPS very carefully. discharged the capacitor using a bulb.
i have also added a video for SMPS working for you reference will hep you for repairing your one
ok
Apr 07, 2011 | Samsung BD-P1600 Blu-ray Disc Player
No power coming on intel desktop motherboard d845
Check the power supply to the motherboard i.e the SMPS, if it is working the fan of the SMPS will rotate. If the SMPS is ATX you can check it without connecting it to the motherboard. Unplug all the SMPS power connectors from the motherboard and then short circuit the green and the black wire of the 20pin connector of the smps, if the SMPS is working the fan of the SMPS will rotate. If the SMPS is in good condition and working, than it might be a problem in the internal circuit of the motherboard.
Check the process here:-
http://www.jestineyong.com/?p=267
Jul 19, 2010 | Intel D845GVSR Motherboard
Output comes on when powered on but turns off immediately
First remove rams and reinsert.
its the problem with your smps. Check with some other smps to your system otherwise use this smps to connect to some other system. If that system working fine with this smps. then may be there is some problem in your motherboard.
Jun 25, 2010 | Acer (56.04200.H22) (5604200H22) 200-Watt...
I went and bought a new power supply today. because i noticed my power supply fan was not working. but my new power supply is not working nither
Sometimes this happens. A newly procured item also does not work. In order to check that your smps is working or not just unplug every output from it and give power supply to smps and check whether the fan is running or not. If not then smps is faulty.
Apr 21, 2010 | Computers & Internet
I have a D946GZIS motherboard. It does not boot whenever i switch it on and press the power button. Also the power led is not glowing. What must be the problem..? pls help ..
Starting at the begining. The wall socket, the plug, the cable, the power socket on the SMPS at the back of your PC, the SMPS, the Output connectors from the SMPS to the motherboard. The power LED not glowing means that the power is not reaching the motherboard. Disconnect and reconnect the power connector on the motherboard. start. No start. Does the fan on the SMPS work? If yes then all components before the SMPS are doing fine. If no then most likely connection socket power cable to the SMPS may be the culprit. This has a lot of load on it. The PC and the monitor both take power from this socket. the answer to your problem lies in the answer to my question whether the fan starts in the SMPS or not. If yes then there is no output from the SMPS and the SMPS need to be given the due attention and if no then there is no power input to the SMPS and various cables and socketc need that attention. In case you need to and can remove and open the SMPS look for bulged or burst capacitors. If found, replace them. Those round cylindrical components.
Nov 27, 2009 | Intel D946GZIS Motherboard
Computer won't power up
loose connections to the motherboard, not having the power cord plugged in all the way, fried power supply, there could be alot of things, try the loose cords, or look inside the computer and check for loose cords.
Jul 13, 2009 | Computers & Internet
Power supply
check your smps then motherboard if power no hope smps no power.change your smps.....
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Open Questions:
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
