Question about Apple Earphone Headphone for i Pod iPhone 3G Nano Touch White
Error message accessory not supported - Apple Earphone Headphone for i Pod iPhone 3G Nano Touch White
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Usually it is caused by corrosion on the cable connectors. Clean the connectors with rubbing alcohol or electrical cleaner and see if that helps. It may only work for a while as over time the corrosion comes back. It usually happens on cheep aftermarket cables.
Posted on Sep 24, 2013
Tip
Verifone error messages
Troubleshooting any Verifone product by any third party company including Fixya.com doesn't provide any support for any error messages. It is a credit card machine and I'm sure for security reasons it was purposly done that way.
You can contact Verifone at:
1-800-834-9133
Mon-Fri 8 a.m. to 7 p.m. EST
Manuals are available at this link
on Sep 02, 2008 | VeriFone (M19755014US1) Magnetic Card...
My hp photosmart c7283 display error 0xc18a0301
I Suggest You To Watch Display Screen Error Messages To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On : HP Printer Support
Apr 10, 2013 | HP PhotoSmart C7283 Ink LigMagenta Re -...
Missing cartridge error message
Please try the following article. It may he resolve you problem.
Print cartridge missing
Other wise Follow Us For
HP Printer Support
Mar 25, 2012 | HEWLETT-PACKARD Hp - DESIGNJET Z3200 24IN...
How to stop error messages on iphone when plugging in an accessory: Every time i switch on my iphone G3, an error message appears saying "This accessory was not made to work with iphone", which...
You should restore your phone. You can do that through iTunes. http://support.apple.com/kb/ht1414
That should take care of the issue.
Dec 12, 2010 | Apple iPhone 3G
One red light
The lower-right quadrant of the Ring of Light flashes red on the front of your Xbox 360 console. You also receive the following error message in multiple languages on your television screen or monitor:
System Error. Contact Xbox Customer Support. This message begins with an error code in the format "Exx," where xx is a two-digit number.
The following indicator will flash on and off repeated on the front panel of your Xbox 360 console:
If one red light is flashing and you receive a different error message or error code than those that were described previously or you don’t receive an error message or code, your console may be experiencing a different issue. In this case, see "References/links."
This problem occurs when your Xbox 360 console experiences a hardware failure.
  1. Turn off your console, disconnect and reconnect all cables, and then turn on your console.
  2. If an Xbox Hard Drive is attached to your console, turn off your console, and then remove the Xbox Hard Drive. Turn on your console, and test for the error. If the error does not reoccur, turn off your console and reattach the Xbox Hard Drive. Run alternate additional tests by having the Xbox Hard Drive connected and disconnected to see whether the error occurs only when the Xbox Hard Drive is connected. For more information if the on-screen alphanumeric error is E67, click the following article number to view the article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red and you receive one of the following error codes and message: "E67, or E68, or E69. System Error. Contact Xbox Customer Support"
  3. If an Xbox Memory Unit (MU) is plugged in to your console, turn off your console, and then remove the Memory Unit. Turn on your console again, and test for the error. If the error does not reoccur, turn off your console and reinsert the MU. Run alternate tests by having the MU connected and disconnected to see whether the error occurs only when the MU is connected.
  4. If this problem continues to occur, contact Xbox Customer Service. Note If the agent cannot help you resolve this problem, you must return your console to Microsoft for repair.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web sites:
U.S. customers - Online console repair
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair)
Outside the United States - Online console repair
http://www.xbox.com/support/ (http://www.xbox.com/support/) Note Online console repair service is currently not available in all countries and regions. For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site:
http://www.xbox.com/support/contact
Oct 08, 2009 | Microsoft Xbox 360 Console
One red light and E74
You see the lower-right quadrant of the Ring of Light flash red on the front of your Xbox 360 console. You also receive the following error message in multiple languages on your television screen or display: E74. System Error. Contact Xbox Customer Support.
You will see the following indicator on the front panel of your Xbox 360 console, which will repeatedly flash on and off:
If one red light is flashing and you see a different error message or code than the one listed above, or you don’t see an error message or code, your console may be experiencing a different issue. If this is the case, please refer to the “References/Links” section at the bottom of this article. CAUSE This behavior occurs when the Xbox 360 console experiences a hardware failure.... loadTOCNode(1, 'cause'); This behavior occurs when the Xbox 360 console experiences a hardware failure. THINGS TO TRY Here are some steps that you can use to try to resolve the issue. Turn off the c... loadTOCNode(1, 'whattotry'); Here are some steps that you can use to try to resolve the issue.
  1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on.
  2. Turn off the console, and then disconnect any accessories that are connected. For example, disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem still occurs. This can help you determine whether the console or an accessory is experiencing the problem. If you determine that an accessory is consistently causing the error, try borrowing another accessory of the same type and testing again using that accessory.
  3. If you continue to experience this problem, contact Xbox Customer Service.
    Note If the agent cannot help you resolve this issue, you may have to return the console to Microsoft for repair.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web Page links: United States customers - Online console repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair) Outside the United States - Online console repair (http://www.xbox.com/support/) Note: Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Mar 27, 2009 | Microsoft Xbox 360 Console
I get an error message everytime I try to record
There is a switch on the VCR that says "tape/other". Change the switch from "other" to "tape" and you should no longer receive this message.
Mar 22, 2009 | ION Audio VCR 2 PC USB VHS Video to...
Printer is displaying 65.12 error
There is no 65.xx error code
the following code should help you.
66.00.15 EXTERNAL DEVICE FAILURE
Description
The stacker or stapler/stacker was removed and then replaced with the printer power was on.
Action
1. Turn the printer power off.
2. Make sure that the accessory is properly seated on and connected to the printer, without any gaps between the printer and the accessory. If the accessory uses cables, disconnect and reconnect them.
3. Turn the printer power on.
4. If the error reappears, record the message, and contact HP Customer Support.
Oct 29, 2008 | HP LaserJet 4350 Printer
One flashing red light on power on circle
Hey steph 1,
According to information provided by the manufacturer, you may see one flashing red light on your Xbox console if there has been some kind of hardware failure. This failure may have occurred in the console itself or an external accessory, so it's recommended that you disconnect all accessories - including your controllers, hard drive and memory units - then restart the console to see if the problem persists. If disconnecting all of these external devices resolves the problem, then the hardware failure is with one of those accessories.
Please keep in mind that this only applies if there was no error message accompanying the flashing red light. If a numbered error message also appears, you may wish to refer to Microsoft's online support database for more information:
http://support.microsoft.com/kb/907536/
There you should be able to find links to pages with troubleshooting steps you can take for the most frequently encountered error messages. Additionally, remember that you can always contact Microsoft directly at their toll-free hotline for further assistance: 800-4-MY-XBOX (800-469-9269).
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | Video Game Consoles & Games
Apple Earphone Headphone for i Pod iPhone 3G Nano Touch White Logo
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
