Question about Cooktops
HOW TO OPEN ELECTROLUX E36IC80ISS1
LOCK NUT ON POWER CABLE IS OFF NEED TO PUT BACK ON.
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
How do I fix an Electrolux induction range element that is not at full power?
Thank you for your post, friend!
I see that you are having difficulty with your induction range element on your Electrolux range. From the information you have provided it is taking longer for items to heat up on that burner. You may need to have that burner replaced and I would recommend having a professional technician come out to perform any repairs. This is not a simple DIY job it may require a possible disassembly of your range. I hope this information has been helpful. -Matt
Feb 18, 2015 | Electrolux EW30IS65JS - 30"Electric...
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
Electrolux E 95 code
Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
F11 reading on control panel of electrolux induction range
Go to the Electrolux website on your computer and look up the model of your range. Th owner's manual should give you what you need...download it!
Dec 25, 2012 | Electrolux EW30IF60IS | 30" Induction...
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
Hello, I have broken and acquired replacement glass top/integrated control panel for Electrolux EW30EC55GS1. The procedure/sequence of dis assembly and reassembly is not obvious. I need some guidance as...
Generally there are screws around just under the lip of the top, on some models the used plugs to disconnect the power to the top. If not you will need to make a diagram or take a picture of wiring so you get it back.
always unplug electricity before attempting to repair on any electrical appliance
Aug 21, 2017 | Electrolux EW36EC55G 37 in. Electric...
ERRORS on Electrolux Icon 30'' Induction Cooktop
Call Electrolux or go to their web site and explain the problem there tech department will be able to tell you if you need a service call or can fix yourself.
Oct 03, 2017 | Electrolux Cooktops
Unlock stove
Unplug w/in an hour and put it back observe if is lock or unlock.
Dec 26, 2007 | Electrolux 23 in. EHS6651P Electric...
Cooktops Logo
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
