Question about Maytag Dryers
PYE/G2300,3300 When you push dial to start dryer, drum does not spin but I hear the motor humming..
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
aborcass
  • 2651 Answers
SOURCE: Will not turn on
the most common fault is a faulty thermal fuse heresd the part number for the replacement LA-1053 you can release the top assy by popping 2 clipps approx 6in. in from each side unde the front of the main top assy. the thermal fuse is located within the heater assy box direct;ly in the rear just under the main top. the kit includes a few tehremos and instructions depending on you rmodel
Posted on Nov 03, 2008
  • 91 Answers
SOURCE: kenmore dryer hums but will not rotate
PRETTY OBVIOUS REPL/ MOTOR
Posted on Jan 03, 2009
  • 1122 Answers
SOURCE: Dryer wont run/push power-sounds like it wants to start/nothing
i get this all the time,yes it is the motor,what happens is the motor gets so weak that it will no longer turn the drum it just hums,a motor on ebay runs about $65,your model number if you want to tackle it is inside the dryer door-mike
Posted on Apr 24, 2009
  • 574 Answers
SOURCE: dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Posted on Sep 03, 2009
Testimonial: "Thanks so much roberta3fan. "
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 17, 2011 | Maytag Dryers
Kenmore dryer model 86950100, when I push the start button it just hums and will not start.First time it did it I waited 1/2 hour then it ran fine for couple days and now it started again, just hums. I...
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
Mar 26, 2010 | Kenmore Dryers
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Buzzer always on, drum won't start spinning
yes you lneed a motor 150.00 to 200.00
May 28, 2009 | Dryers
When I push the start button, the unit just buzzes or hums.
You have a broken drum belt. The hum you hear is the motor spinning at high speed.
Apr 21, 2009 | Maytag MDG2706A Gas Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
