Question about Home
Triton seville I have only had my shower since August and it was fitted by an electrican. When on high setting the water goes in a cycle of warm,boiling,warm,freezing within minutes. Triton have said they will come out but maybe a charge if not the actual shower. Has anyone come across this problem and is it likely to be a fault with the shower?
  • 40 Answers
I would contact the installer first and see what they can come up with. Since the Triton system is self contained, there shouldn't be any other factors involved. Do you have their troubleshooting guide?
Posted on May 18, 2013
keemo68
  • 1263 Answers
SOURCE: Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Posted on Sep 03, 2008
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
  • 34 Answers
SOURCE: triton t80i water only warm in winter
That sounds like a water heater problem, wheres the heater at in your home. If it is effected by the outside weather i.e. the heater is in a cold environment then it would effect the hot water output. try turning up the thermostat on the heater if it is gas then it should be knob on the outside if it is electric you will need to remove the top or the bottom cover and adjust it with a screw driver. If this does not work the let me know and we try some other things. With the weather/temp outside effecting the water temp in the shower then I have a hard time believing it is the shower its self.
Posted on Feb 06, 2009
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
Low pressure to a triton as200xt can i fit a t22i pump in front of the shower
I have just put a new triton as2000xt and I have no water coming out.
Mar 16, 2011 | Home
Dial not working correctly, set on low numbers water comes out at high pressure, set it on high numbers and the water pressure comes out on low pressure ???? why.... the item in question is a Triton Madrid...
It sounds like the numbers are for the temperature indication and the higher the temperature the more slowly the water runs because it takes longer to heat it.
Apr 16, 2010 | Home
Nov 11, 2009 | Water Pik Waterpik& Elements& Fixed Mount...
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
how on earth is this related to gaming consoles or PS3 ??
Please post under correct sections next time.
Anyways, it looks like a common problem for the Triton Shower, and it might cost you some $90 to fix it.
http://www.comparestoreprices.co.uk/showers/triton-martinique-10-5kw.asp
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
The unit will not heat any water, press hot but goes straight to
probley heater eliment ? if not megga dear unit buy new one probly cheaper as long as u fit ure self
May 10, 2009 | Home
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
172 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
