Free up space on my simple tech 250 mg external hard drive
Find instructions to free up space on my signature simple tech 250 mb external hard drive?
eastpole
  • 22 Answers
SOURCE: does simple tech 250 drive need an external power source?
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
Posted on Sep 04, 2008
damien729
  • 221 Answers
SOURCE: seagate free agent go 250 gb external / macbook pro os x tiger
If you can see the drive in Applications --> utilities --> Disk Utility, then you will be able to reformat it in the Mac OS format and read it.
Good day, Damien
Posted on May 30, 2009
Geekman
  • 32281 Answers
SOURCE: Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Posted on Sep 13, 2009
bob_computer
  • 3153 Answers
SOURCE: Simple Tech 250 GB external hard drive won't work
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 23, 2009
  • 191 Answers
SOURCE: I need driver software for my external hard drive
I checked for one on SimpleTech's (Hitachi) website. The only show a driver for Windows 98. This leads me to think you don't need any drivers. USB is hot pluggable. Just plug the drive in. Windows XP/Vista/NT will plug a driver in for you (a USB driver). Drive will be given an access letter. You can then access like any other drive from Windows Explorer. Sometimes, USB drives have additional software on them (known as firmware) that you can then run directly from the drive. The firmware is not require to use the drive, but may offer features like backup software.
Posted on Oct 11, 2009
What does it mean when my drive storage appear red and says there is only 250 mb left?
it means you've filled up your hard drive.
you need a minimum of 15% free space on your hard drive or it will start going very slow and won't work properly and the hard drive will be constantly running.
you need to remove stuff from it onto an external drive or just delete it.
Feb 22, 2016 | HP SimpleSave Computers & Internet
My passport is originally 250 GB but now it says that it's only 94 MB. I don't know what happened.
is that a free space and used space graphic? or does the entire disk(use start my computer right click on hard drive and see what total amount of space says)
if you have been using this for a while, that would explain the lower figure but this graphic will clearly show the balance on that drive
here's a link for a free disk optimizer that might help too
May 19, 2012 | Western Digital WD Passport 250GB Portable...
I've met space limit for my SimpleTech external drive even though my internal drive still has space and both are 250 GB. Are there SimpleTech programs taking up space and if so how much of that 250 GB...
Your internal drive is different than your external drive. If you put more files onto your SimpleTech drive, then that one is going to fill up faster. The best thing to do would be to go through your SimpleTech drive and delete anything that you don't need. I don't remember my SimpleTech drive coming with any software on the drive, but if it did, it didn't take up much space.
Aug 21, 2011 | SimpleTech Signature Mini 250GB External...
Simpletech external hd 250 Gb is not reckon by vista (though was before) but works ok on XP. USBs are ok. It appears in disk management (says it is working properlly but no letter asigned to it) but does...
You need to partition it and format it inside of disk manager. You can do this by right clicking on the device (the gray box next to where it said there was no letter assigned)and selecting initialize.
May 04, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
How can I lock my simple tech hard drive from other users
there are many softwares that you can use. Tryb the following link. it's very user friendly.
http://www.newsoftwares.net/folderlock/
Mar 24, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My Hp Slimline won't recognize my new Simple Tech Mini-Drive
I`m David ncc student , question is about the characteristics of various network computers (NCs) currently on market? please help me
Mar 08, 2009 | HP S3120N Pavilion Slimline Desktop...
Simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try driverguide.com for drivers of the disk.
Nov 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech signature mini 169 GB
how do I reset my format from a Windows to a MAC
Oct 25, 2008 | SimpleTech Signature Mini 160GB External...
Computers & Internet Logo
David Payne
David Payne
