Question about Ragalta RWC-195 Thermo Electric Cold And Hot Water Dispenser
Why dosent the light for the cold water stay on?
My obdll pocket reader shows fuel comp on 02 kia spectra; whats the best way to track this down. I hope is not a fuel injector
Is your check engine light on ? Fuel comp. is fuel system monitor test complete , along with HO2 , misfire , cat, etc... Nothing wrong ! OBD Readiness Monitors Explained OBD Auto Doctor Scantool Garage
Oct 20, 2015 | Kia Cars & Trucks
It dosent stay hot when you turn it up the water is cold
post the make & model please
this post is under "Generic problem for all Air Conditioners"
Jun 15, 2008 | Heating & Cooling
Water wont go into the machine but the wash light comes on here a clink but dosent fill with water an start cycle help plz
IF YOU ARE SURE THE WATER SUPPLY IS ON. SHUT OFF WATER TO MACHINE AND REMOVE HOSES ON BACK OF MACHINE AND CK SCREEN ON VALVE THEY CAN BECOME PLUGED AND WILL BLOCK WATER FLOW. PUT THE HOSES IN A BUCKET AND TURN ON JUST TO BE SURE IT IS NOT ANOTHER PLUMBING PROBLEM.
Apr 21, 2014 | Indesit WA 115 Front Load Washer
Auto chlor RP 92 QT
Just a note, if water is cold, there is an Automatic "Stays Off" mode when water temperature is cold. Chlorine won't be generated with cold water. Can't remember what "Number" that is, but unit will not turn on with cold water.
Dec 26, 2013 | Pool & Spa
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Bike overheated have replaced faulty thermostat warning light stays on and will not start, any ideas.
Unplug battery and clear code. If this dosent work than the water temp sensor was probably damaged when it overheated.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Oct 27, 2013 | 2004 Triumph Daytona 600
When i stop at stop sign or red light carstalls dosent stay idiling
Good Morning Vinnie: Does the fault occur on a cold engine or only when it has reached operating temperature? Also, is the Check Engine Light on?
David
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 14, 2011 | 1998 Oldsmobile Intrigue
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Ragalta RWC-195 Thermo Electric Cold And Hot Water Dispenser Logo
48 people viewed this question
Top Ragalta Water Filters & Coolers Experts
Tom Chichester
Are you a Ragalta Water Filter and Cooler Expert? Answer questions, earn points and help others
