Question about aFe 2002 Jaguar S-Type - 4.0L V8 - Air Filters
Jaguar engine failure
How to determine if timing chain job or engine replace
  • aFe Master
  • 17,115 Answers
How many miles are on it? What is it doing?
Posted on May 12, 2013
25hp kohler hot start problem. Replaced fuel filter, plugs and cleaned air filter - same problem. it won'd restart when hot.
3 possibles come to mind
fuel vaporization in the line to the carby or in the carby bowl (check float level adjustment)
valves are being held open when hot--- valve stem lengths increase reducing tappet clearance___adjust valves when hot
check coil/ ignition module for failure when hot as they can open circuit ./ short circuit when internal components fail from heat
Sep 27, 2016 | Kohler Command V-Twin Horizontal Engine...
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
Overheating
After replacing or refurnish engines head is recommended to replace water pump and inspect thermostat, radiator, and cooling fan. Most of the time engines overheat is because there is not enough water circulation thru the head due to malfunctioning water pump, radiator, thermostat and or radiator's cooling fan. By just fixing the damaged head you may not be solving the problem that originally burned your head gasket.
Apr 03, 2014 | Spectre 2001 Audi A3 - 1.8L 4-cyl. engine...
Pulled cord out to end, will not retract
whats the volts and amps for my Dirt Devil Jaguar II Canister Vac Model: SD40020?
Apr 16, 2013 | Dirt Devil SD40020 Jaguar II Canister...
Mitsubishi fuso 2008 check engine light
Hello
When the service engine soon light (Also called the check engine light) is turned on this is to alert you to the fact that powertrain control module (computer) has detected a failure somewhere in the systems it controls, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Jun 23, 2012 | Mitsubishi 4 Fuso Truck Fe 2005 / 2008 Air...
My EcoQuest Fresh Air unit stopped working. The fuse seems to be good. It will not turn on. Any suggestions?
A common problem with the Fresh Air when they are not cleaned regularly is heat build up, which may cause circuit board failure. There are two processors on the circuit board which burn out. The circuit board can be repaired rather than replaced at a very reasonable cost and one repair facility will guarantee their work for 1 year. Call toll free (336) 499-2505 between 8: 00 AM and 5:00 PM Eastern time and they will gladly help you.
Jun 08, 2012 | Ecoquest Fresh Air Air Purifier
aFe 2002 Jaguar S-Type - 4.0L V8 - Air Filters Logo
Top aFe Air Purifiers Experts
Dan Webster
Dan Webster
Pcm2048
Are you an aFe Air Purifier Expert? Answer questions, earn points and help others
