Question about Bissell Supreme Sweep Turbo Rechargeable Compact Sweeper
Bissell 45A8-E not charging properly
Need a manual on a bissell shampooer #47a2r
go to bissell.com and you can download from there..make sure its bissel.com and not any of the others on the page, they all charge a fee....you can normally download or view a manual on just about anything for no charge if you go directly to the company that makes the product
Oct 18, 2014 | Bissell ProHeat Shampoo Bottle Assembly...
I just adopted a Bissell 1719 spot cleaner from my sister-in-law but they don't have the manuals. How do I change the battery? I don't see any removable clips, just screws in the unit housing
Good evening,
Please see the below link for the user guide/manual to this unit:
http://www.retrevo.com/support/Bissell-1719-Vacuums-manual/id/10659bh140/t/2/
This unit should include a charger for the battery. Below is the instructions on how to charge and maintain the battery.
If you need to actually replace the battery, the instructions below show the process:
Just a quick note, these units do come with a Ni-Cad battery, which should last you at least 5 years (closer to 6 or 7), and make sure that dispose/recycle the battery properly.
This can all be found in the manual (link provided at the top). I hope this helps, and please let me know if you need clarification. Please rate this solution!
Thanks,
~PCF
Mar 15, 2011 | Bissell 1719 Spot Lifter 2X® Handheld...
Hello, my bissell vacuum is making a loud noise. How can i stop it from making this noise.
Hello, this is Ava with Think Crucial.
To fix any noise issues that your Bissell vacuum gives, a proper maintenance will do the trick. Most of the time, cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. You may need to refer to your User's Manual for instructions on how to do proper maintenance.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 11, 2011 | Bissell 6594 PowerForce Bagless Upright...
Had to replace bissell pro heat pump wondering if I put the hoses in proper palce
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 05, 2010 | Bissell Vacuums
Replacing smart mix plunger bissell proheat model 7901 procedure for proper installation
heatman101
May 17, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell LOUD noise!
To fix any noise issues that your Bissell vacuum gives, a proper maintenance will do the trick. Most of the time, cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. You may need to refer to your User's Manual for instructions on proper cleaning and maintenance.
Ava B.
Feb 01, 2010 | Bissell Vacuums
How do i change the brush on my 5770 bissell
BISSELL model 5770 has a lifetime belt warranty. You can locate a BISSELL authorized service center at www.bissell.com and the belt should be replaced at no charge.
Oct 09, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Carpet cleaner not working properly will not send out the water
his is a very common problem with Bissell Carpet Shampooers...
Fortunately it has a very simple solution.
The problem is caused by blocked water jets ! and if your machine is still under the two year guarantee,Bissell will collect and repair very quickly free of charge !
Good Luck !
Call them on
0844 888 66 44 - Option 1 (UK Only) (Monday - Friday, 9am - 4pm)
Sep 03, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Supreme Sweep Turbo Rechargeable Compact Sweeper Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
