Corel Cdgsx6enhbb coreldraw graphics suite x6 en Logo
210010 0 id coreldraw x6 - Corel Cdgsx6enhbb coreldraw graphics suite x6 en
2 Related Answers
Anonymous
  • Posted on Jul 20, 2013
SOURCE: activation code for coreldraw x6
Hello! I need the serial number and activation code for corel x6 with id 0 410003, can you pass me please???
oranggila
  • 221 Answers
  • Posted on Dec 25, 2013
SOURCE: i need activation code for corel draw x6
you can search it using Google
1helpful
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Activation code
Check on the disk and the disk sleeve.
Terry
Corel x6
Whats the question ? you have the activation code
ACTIVATION CODE
You will need to contact the publishers of Corel Draw.
COREL X6 ACTIVATION NO.
I need help!
What is the activation code for this serial:
Installation code: XUGR - 7WNM - TT8F - V9QH - RK3T
Serial number: DR16R22-TSE76XG-28TBUTW-EPUX8D8
Activation code:?
Can someone save me?
I need very urgent, I have a paper due
Send me the code generated for me by my email. ([email protected])
Activation code off
CorelDRAW X6Installation Code:X4DB-7WNM-TT6E-2QFZ-XFBTSerial number:DR16R22-948R22S-L6BHRBG-WNGUZM8Activation Code:??????????ID:210010 -11pls. send me the activation code [email protected]
Top Corel Computers & Internet Experts
k24674
Kolbrun...
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
