Question about Gestetner 3255 3265 3270 3355 3370 5502 Lower Fuser
Error sc 101 oficio
My machine gives Error sc101 What is the reason of this code? How do I fix it? Please guide. Thank you
SOURCE: Gestetner DSM645SP Error Code SC 322
After research it seems this problem is not easily fixed.
Posted on Jan 17, 2009
  • 86 Answers
SOURCE: Hie I have a Gestetner
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Good luck and please rate me, thanks.
Posted on Feb 03, 2009
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
santosj27
  • 263 Answers
SOURCE: I have Nashuatec SDM 616 photocopier. I was doing
This code is related to a current leak in the Charge Roller.
The first thing i advise you to do is clean the plug of the PCU (fotoconductor unit) and of course the PCU.
If you take out the PCU you will see a metallic pin and a spring (in the back of the machine). Clean it or vacuum it (could be dust of toner).
This should be it.
If that doesn't work you probably have a defective High voltage supply board.
Hope that helps
Posted on Mar 03, 2011
  • 34 Answers
SOURCE: how do i fix error
The fuser roller needs to be replaced. It is likely coming apart and binding up the fuser motor.
Posted on Mar 12, 2011
Please guide me what is the problem and how can I change the developer of the Bizhub 500 B&W Photocopier.
Hi
There is a very good summary list of all the error codes for your machine, which you may find useful, here:
Error Codes Konica Minolta bizhub 500
My main reason for giving you this link is that you cam get a service manual here for a very reasonable cost which should give you step-by-step instructions and diagrams for the change you want to do.
Good Luck
Jan 13, 2015 | Office Equipment & Supplies
My aficio 1022 is showing code sc101. How can I fix it
SC101 is scanner home position error. Check the sensors or the white plate, usually its dirty.
Aug 13, 2014 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh photocopier 1055 code sc101
for sc101
Exposure lamp error
The standard white level was not
detected properly when scanning the
white plate.
Dec 08, 2012 | Ricoh Aficio 1013F Copier
Functional problem sc101
SC101 is an exposure problem.check if at on of the machine exposure lamp is light in a few sec. then off then follow this as a guide
SC101 D Exposure LampError At trigger on, thelamp was not detected on. Exposure lampdefective Lamp regulatordefective Exposure lampconnector defective Dirty standard whiteplate Dirty scanner mirroror scanner mirror out of position SBU board defective SBU connectordefective IPU defective
Aug 28, 2011 | Ricoh Aficio 450 Copier
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
Error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
Jun 10, 2009 | Lanier Office Equipment & Supplies
I have one copiar machin 5455 my problam is stating machin showing error sc101 .
Sc101 is a scanner home sensor error. Try removing the exposure glass, and clean the WHITE STRIP on the underside of the glass. If that does not work, there is a mechanical problem with the scanner such as a broken drive cable, which will require a trained technician to repair.
May 03, 2009 | Office Equipment & Supplies
ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
Jul 09, 2008 | Ricoh Aficio 1013F Copier
Error code Sc101
SC101 can be caused by a dirty WHITE LEADING EDGE STRIP. This is located under the left side plastic strip that holds down the exposure glass on the left side. Remove the screws, and flip over the glass holder. Clean the white strip with glass cleaner, and reassemble. If SC101 reappears, the scanner drive pulley screws are loose or broken off. A service technician is required for this repair.
Feb 20, 2008 | Lanier 1205 Copier
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
Gestetner 3255 3265 3270 3355 3370 5502 Lower Fuser Logo
60 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
