Question about Nikai DV7000 Camcorder
New nikai DV925 video cam
How do you get the camera to initally charge a new lithium battery?How do you know whwn you are putting the battery in corectly? I cannot get the camera to charge the battery. The indicator light blinked but still after 8 hours the battery is not charged and I cannot turn on ther camera
  • irishwiseguy Apr 17, 2008
    Im having the exact same problem with my DV7000. I put it into the charger and its red at first but then goes green so I thought it was ready but NOOOTTT. The camera stays on for like 20 seconds then shuts off.
  • Sandralea Oct 30, 2009
    Were can I buy a battery and charger for a Nikai DV925
    [email protected]
    New Friend:
Go buy a new camera..
Posted on Oct 30, 2009
SOURCE:
Why doesn't it recognize the correct battery?
hi,
If your camera do not recognize the original battery, it means some wrong information is stored in its software data, to override this please open the camera take out the small memory backup lithium battery, short the battery contact , after a five minutes connect that battery again.
Mar 02, 2016 | Sony Video Cameras
Toshiba PDR-3300 Digital Camera
Hi this is common problem if your sure that these batterys are new and you have used that make and type of battery before than the problem will be on the board of the camera itself.
If these batterys are ones you have not used in your camera before then the chances are these batterys are just not powerfull enough so you can by a recharge pack for your camera ok so let me know if its new batterys and if you have used this type before.
Also insted of using the lcd can you turn the screen of then try taking picture using normal view finder as you would on a none digital cam
It could just be that the batterys you brought are faulty and might be worth trying another set before giving up.
These camera usuall wont switch on with normal batterys so just try another set or if you have let me know.
If the battery says low bat then goes off then these batterys will not work if tryed again but if you can get camera on turn off the screen then try taking picture ok get back to me and let me know ok
Apr 06, 2008 | Toshiba PDR-3300 Digital Camera
Put new batteries in my wildview cam works for a second than stops
Rechargeable or one use type batteries?
Could be it was a faulty pack.
If recharge type did you give them their first charge for around 24 hours?
Always use Alkaline or Lithium Ion single use batteries.
If rechargeables always use a high number mah rating; 3.2s will go down quick, 8. (whatever it is) will sustain.
If none of these help try Technical Support on the website of your camera's manufacturer.
Sep 26, 2011 | Cameras
My dvd camcorder has serious batterie problems what should i do?
dear sir,
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
still if the same,then plz change your battery(lithium ion battery or the battery prescribed for the model,plz note:before changing battery make sure yu buy the battery specified for your cam)
thank you...take care
Oct 08, 2010 | Canon DC100 DVD Camcorder
Hey just purchased samsung ST500 online. first time using a digi cam dat uses Lithium Ion battery. how do u charge it???
just plug it in with the normal charger, but make sure the battery is as flat as you can let it because over time the battery will become rubbish if its over charged, Lithium Ion batteries can be real pains.
Apr 11, 2010 | Samsung DualView TL220 Digital Camera
Fully charged battery in and it only lasts few minutes
you have to buy lithium battery's or lithium rechargable's. that camera should of came with lithium battery's did you get it used? and it should take usb.
Jan 02, 2010 | Sharp Viewcam VL-AH151U Camcorder
Low battery
Yeah Lithium Ion Batteries has a limited shelf life.
Mar 30, 2009 | Panasonic Video Cameras
Kodak easyshare c613
Are you using Lithium batteries?
Most Kodak models are only happy running on Lithium batteries.
I have two Kodak cameras, both had various power-related problems. Since using Lithium batts, not a single glitch.
They are more expensive, but they end up costing less compared to the amount of alkaline batts replaced.
Worth a try.
Jan 01, 2008 | Kodak EasyShare C613 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Nikai DV7000 Camcorder Logo
578 people viewed this question
Top Nikai Video Cameras Experts
Ekse
Marvin
Marvin
Are you a Nikai Video Camera Expert? Answer questions, earn points and help others
