Question about D-Link DP-301U (790069251979) Print Server
The network connection for the printer has gone
The network connection of the printer is not working. and the pc has been connected to the printer is not accessible. what can i do for this matter? i dont know how to reset and to setup the dlink dp-310u print server.. pls help me..
    President:
  • 1,114 Answers
You can get setup guides and download firmware from the following link: http://support.dlink.com/products/view.asp?productid=DP%2D301U Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 11, 2007
SOURCE:
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
1320tn - network cable link light does not turn on. I have changed cables, turned off power, held down reset button and nothing works. Also, network config will not work when pressing in reset button. ...
Take a breath, relax. The link light means that you have established a connection with whatever is at the other end of the network cable. You omitted that info. If the printer is connected to a switch, try a different port. If the printer is connected to a router and you have a free port, connect it there. If the printer is connected to a PC, that port could be bad. If you have another printer, try plugging it into the PC. As long as you don't have the handshake between PC and printer you won't see any IP address. I'm not familiar with the 1320. Saying that, I believe that the network interface is on the formatter board. And yes that could be bad. Doesn't the 1320 have a USB port? Have you tried that.
Before you spend any money, try connecting the printer to a different PC or a laptop. If it works, your printer is not the problem. If it still fails, call for service, because the formatter will need replacing.
Aug 06, 2011 | HP LaserJet 1320 Printer
The print spooler is not working on my dell inspiron 530. I have tried to start it, but it will not start. Help!!!!!
Have you gone to start, settings printers and faxes, right click on the printer in question, click on the advanced tab and click next to "spool document so it prints faster"? You will need to do this on the computer connected to the printer. Computers that are connected thru a network won't be able to make this change.
Let me know if this information is helpful.
Brian
Feb 25, 2011 | Dell Computers & Internet
I have a Panasonic KX FLB881 MFC Laser Printer purchased in 2/09. Problems started about 60 days ago. Incoming fax calls ring and ring and the unit will not pick-up. Shortly thereafter network...
The printer has gone into cascade failure, it would require circuit boards to be replaced and with the history I would use it strictly as a printer. The cost of repair would put you over the price you originally paid for the unit, and as you pointed out the mechanics of the item is still fine, I agree with the fact use it until it breaks down.
Jan 07, 2011 | Panasonic KX-FLB881 All-In-One Laser...
Microphone not working- I have: updated the driver; run the troubleshoot options; gone into All Programs/audio and adjusted the main volume. It is Realtek. I have tried everything using Line In option...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Pavilion m7100y (PX189AV) PC Desktop
Use of HPJ4680 in a network with Mac & PC connected to router
Ok what you do is, install the printer as a LOCAL one on one of the PC's, Probably the XP, one, would be best. or perhaps the PC; actually "Connected" to the D-link router & Modem, then Now install this printer , as a LOCAL, printer, and set as DEFAULT, enable Printer Sharing. Now, ALL PC's MUST, have a Name, Belong to the same Workgroup, have a Password. On the "Other" PC's Install the Printer as a Network Printer, browse for it and connect. Print a test page from each. Remember the PC with the printer attached, must obviously be ON or the "Others" cannot connect and print.. Make sure all network permissions are set sharing is set, especially on the Win 7. Just make sure they can all "See" each other first, before try all this.. the network MUST be intact and communicatable from each PC to at least the PC with the printer attached. I have included 3 links below, to help
kb.parallels.com/4886 - support.apple.com › Support -
support.microsoft.com/kb/239418
Mar 05, 2010 | HP Officejet J4680 InkJet Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
I want to downlaod the Hp LaserJet 1018 driver
Dear User,
Pl open my networkplace in your computer after going(via network) to that pc connected to printer.
when open that pc pl see printer and right click on printer to press connect.
printer is connected to your computer.
Regards,
Ravindra Shah
Jun 29, 2009 | HP LaserJet 1018 Printer
AFTER SP3 installed network printer not working
You should go into Start>Printers and Faxes, write down the exact printers that you have (including server name or IP address) and then delete them by right-clicking on each printer and removing it. Once they're gone, add them back by using the Add Printer wizard or by browsing the network to find them and re-connect them. Since you specify that the network printers aren't working, I'm guessing that local (USB, parallel) printers still work properly. This would rule out the local print spooler, and since you didn't mention that everyone else can't print, it's probably not the print server either.
May 13, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
EPSON STYLUS C90 PROBLEM
Let's start here:
Go through file and printer sharing in all three
Ensure that in PC#2 the Epson is the Deafault Printer chosen
Install the printer locally and directly on PC3 to test from the paralell ports. If it works normally, we continue to susperct network glitches.
Are you using the same operating system in all three PCs?
Let
Feb 18, 2008 | Computers & Internet
D-Link DP-301U (790069251979) Print Server Logo
510 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
